蓝牙模块 ADXL345
我买了一个ADXl345的模块。我找到了与电脑通讯的程序,但是我想要让回馈的变量可以控制。请求大神帮助 (可否帮我加一个x轴在0-100的范围,led10灯亮)
#include
#define Register_ID 0
#define Register_2D 0x2D
#define Register_X0 0x32
#define Register_X1 0x33
#define Register_Y0 0x34
#define Register_Y1 0x35
#define Register_Z0 0x36
#define Register_Z1 0x37
int ADXAddress = 0xA7 >> 1; // the default 7-bit slave address
int reading = 0;
int val = 0;
int X0, X1, X_out;
int Y0, Y1, Y_out;
int Z1, Z0, Z_out;
double Xg, Yg, Zg;
void setup()
Wire.begin();
Serial.begin(9600);
delay(100);
// 能够测量数据
Wire.beginTransmission(ADXAddress);
Wire.write(Register_2D);
Wire.write(8); //measuring enable
Wire.endTransmission(); // stop transmitti ng
void loop()
//--------------X
Wire.beginTransmission(ADXAddress); // transmit to device
Wire.write(Register_X0);
Wire.write(Register_X1);
Wire.requestFrom(ADXAddress, 2);
if (Wire.available() <= 2)
X0 = Wire.read();
X1 = Wire.read();
X1 = X1 << 8;
X_out = X0 + X1;
Xg = X_out;
Serial.print("X= ");
Serial.print(Xg);
Serial.print(" ");
delay(1000);
回帖 (1)
2019-2-27 10:07:03
用0000试试
用0000试试
举报
更多回帖
