引用: 脑洞大赛9 发表于 2019-2-26 11:29
除非您的衰减器大约超过1米,否则纹波看起来是来自校准残差。
最有可能在传输跟踪项中(因为衰减器的匹配将消除源和负载匹配残差的影响。纹波水平(+ -0.02 dB)几乎是可预测的,假设残差为-58 dB
匹配(源或负载)和原始匹配。因此,具有15 dB源和负载匹配以及43 dB残余源和负载匹配的系统将产生这样的响应。
> {quote:title = Dr_joel写道:} {quote}>除非您的衰减器大约超过1米,否则纹波看起来来自校准残差。
最有可能在传输跟踪项中(因为衰减器的匹配将消除源和负载匹配残差的影响。>>纹波电平(+ -0.02 dB)几乎是可以预测的-58 dB产品
剩余匹配(源或负载)和原始匹配。因此,具有15 dB源和负载匹配以及43 dB残余源和负载匹配的系统将产生这样的响应。谢谢Joel,衰减器是典型的长度。
N衰减器(即那些波纹是否过量,因为我有* 8720D *正确的安捷伦测试电缆* 3.5 mm到N型适配器来自安捷伦校准套件* 85032B校准套件?如果有人告诉你,你会告诉他们去吗?
正确地校准他们的VNA,或者你认为可以接受吗?可以合理地期望用更好的VNA和带有滑动负载的校准套件做得更好吗?我有一个85055A验证套件,但不确定我是否可以使用它
85032B cal kit,所以真的没有任何办法
看看我的校准是否是可接受的。
DaveEdited:drkirkby于2013年4月21日下午2:18
以上来自于谷歌翻译
以下为原文
> {quote:title=Dr_joel wrote:}{quote}
> Unless your attenuator is on the order of more than 1 meter long, the ripple looks to be from calibration residuals. Most likely in the transmission tracking term (as the match of the attenuator will eliminate the effects of source and load match residuals.
> The level of the ripple (+-0.02 dB) is nearly exaclty what would be predicted given -58 dB product of residual match (source or load) and raw match. Thus, a system with 15 dB source and load match and a 43 dB residual source and load match would produce such a response.
Thank you Joel,
The attenuator was a typical length for an N attenuator (i.e. << 1 m long), so we can assume it is calibration residules.
Are those ripples excessive given the kit I have
* 8720D
* The correct Agilent test cables
* 3.5 mm to N adapters from an Agilent calibration kit
* 85032B cal kit
If someone showed you that, would you tell them to go and calibrate their VNA properly, or would you think that acceptable?
Could one reasonably expect to do better with a better VNA and cal kit with sliding loads?
I've got an 85055A verification kit, but are not sure if I can use it with my 85032B cal kit, so don't really have any way of seeing if my calibration is acceptabel or not.
Dave
Edited by: drkirkby on Apr 21, 2013 2:18 PM
看看我的校准是否是可接受的。
以上来自于谷歌翻译
以下为原文
Thank you Joel,
* 8720D
* 85032B cal kit
Dave
举报
