Cypress技术论坛
直播中
李亮
8年用户 212经验值
私信 关注
[问答]
当出现正在加载调试符号消息时,PD5.0 SP4挂起
嗨,pd5.0 SP4挂在“加载调试符号信息。…出现。我尝试了几个POD时钟频率。问候,罗尔夫
以上来自于百度翻译
     以下为原文
          Hi,
PD5.0 SP4 is hanging when the message "Loading debug symbols . . . " appears. I tried several POD clock frequencies.
Regards,
Rolf
回帖(2)
李富贵
2019-2-26 14:55:25
你好,罗尔夫,你能提供更多的信息吗?1。是问题发生时,你正在下载的程序在调试模式的荚?2。可以请你澄清“我试过好几种POD时钟频率”?3。请提供详细的电脑配置和操作系统。
以上来自于百度翻译
     以下为原文
          Hi Rolf,
Can you provide some more information?
1. Is the problem occuring when you are trying to download the program to the pod in debugger mode?
2. Can you please clarify "I tried several POD clock frequencies"?.
3. Please provide details on the PC configuration and operating system.
举报
于惠
2019-2-26 15:12:01
嗨,GANSIH,当然,这里有一些细节:1)在构建项目并按下“下载到模拟器”按钮后,会出现一个信息:“加载调试符号”。…在此之后,状态栏中的“下载[项目名称]”消息将出现。然而,它在前一个消息中停滞不前,你唯一能做的就是按下“重置”按钮。2)当你不连接一个ICE时,在“项目设置调试器”字段中有一个组合框,它允许你选择调试器POD频率(50千赫)。5000千赫)。我猜这个选择是错误相关的,不应该被用户调整。3)我使用XP+SP3在3GHz的赛隆上,带有2GB的RAM。我重新启动,重新安装PD,它没有帮助。4)我提交了一个案例,即ftbqk7,我终于回到SP3A,结合SP4的高科技编译器(PRO V961PL6),它对我来说很好。我会在笔记本电脑上试用几天。问候,罗尔夫
以上来自于百度翻译
     以下为原文
          Hi Ganesh,
Sure, here are some details:
1) After building the project and by pressing the 'download to emulator' button, a message comes up: "Loading debug symbols . . .". After this the message "Downloading [project name]" in the status bar should appear. However it stalls at the former message and the only thing you can do is press the 'Reset' button.
2) When you don't connect an ICE, there's a combo box in the 'Project-Settings-Debugger" field which let you select the debugger POD frequency (50 KHz... 5000 KHz). I guess this selection is error-related and should not be adjustable by the user.
3) I use XP+SP3 on a 3GHz Celeron with 2GB of RAM. I have restarted, re-installed PD and it doen't help.
4) I've submitted a case, #FTBQK7
I finally reverted back to SP3a, in combination with the SP4 HI-TECH compiler (Pro V9.61PL6) which works fine for me. I wil try in a few days on laptop.
Regards,
Rolf
举报
更多回帖
