赛灵思
直播中
李丕海
8年用户 197经验值
私信 关注
[问答]
无法找到关联的.msk文件
我们正在尝试将旧设计重新投入生产,以满足特定客户的需求。
我找到了.bit文件,但无法找到关联的.msk文件。
如果没有.msk文件进行验证,我们的测试部门不会将.bit文件写入FPGA
有没有办法从现有的.bit文件创建.msk文件,还是需要重新设置设计和创建新文件?
以上来自于谷歌翻译
以下为原文
We are trying to put an older design back into production for a specific customer.  I have located the .bit file, but cannot find the associated .msk file.  Our test department will not writ a .bit file to an FPGA without a .msk file to verify against.  Is there a way to create a .msk file from an existing .bit file, or will I need to re-route the design and creatre new files?
回帖(2)
刘鹏
2019-2-26 11:18:30
嗨错开,
抱歉,没有任何办法。您需要重新路由设计以生成.Bit和.msk文件。
谢谢
-Pratham ------------------------------------------------
----------------------------------------------请注意 - 请
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-
以上来自于谷歌翻译
以下为原文
Hi stagger,
Sorry there is no any way of doing it.you need to reroute the design for generating  .Bit and .msk file.
Thanks
-Pratham
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
举报
王蓓
2019-2-26 11:26:38
是的 - 这就是我害怕的。
无论如何,谢谢你的回复。
以上来自于谷歌翻译
以下为原文
Yeah - that's what I was afraid of.  Thanks anyway, for your reply.
举报
更多回帖
