PADS技术论坛
直播中
chen2832
12年用户 85经验值
擅长:嵌入式技术
私信 关注
[经验]
Cadence16.6原理图中DRC出现错误: Possible pin type conflict GND Power Connected to Output的解决方法
DRC错误报告:
Checking Electrical Rules
ERROR(ORCAP-1628): Possible pin type conflict GND  Power Connected to Output
                    RK3288_BOX_Ref, 14.AP6XXX-WIFI/BT  (205.74, 30.48)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS47  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 17.78)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS45  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 127.00)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS51  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 27.94)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS50  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 25.40)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS49  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 22.86)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS48  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 20.32)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS54  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 35.56)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS53  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 33.02)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS52  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 30.48)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS57  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 43.18)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS56  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 40.64)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS55  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 38.10)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS61  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 53.34)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS60  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 50.80)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS59  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 48.26)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS58  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 45.72)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS62  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 55.88)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS64  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 60.96)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS3  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 20.32)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS2  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 17.78)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS63  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 58.42)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS1  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 15.24)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS46  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 15.24)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS66  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 66.04)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS65  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 63.50)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS4  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 22.86)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS68  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 71.12)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS6  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 27.94)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS5  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 25.40)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS67  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 68.58)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS9  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 35.56)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS8  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 33.02)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS69  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 73.66)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS7  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 30.48)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS71  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 78.74)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS11  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 40.64)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS10  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 38.10)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS70  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 76.20)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS14  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 48.26)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS72  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 81.28)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS13  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 45.72)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS12  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 43.18)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS74  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 86.36)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS16  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 53.34)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS15  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 50.80)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS73  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 83.82)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS19  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 60.96)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS75  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 88.90)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS18  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 58.42)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS17  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 55.88)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS77  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 93.98)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS21  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 66.04)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS76  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 91.44)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS20  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 63.50)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS24  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 73.66)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS78  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 96.52)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS23  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 71.12)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS22  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 68.58)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS80  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 101.60)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS26  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 78.74)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS25  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 76.20)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS79  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 99.06)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS29  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 86.36)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS81  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 104.14)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS28  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 83.82)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS27  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 81.28)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS83  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 109.22)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS31  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 91.44)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS30  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 88.90)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS82  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 106.68)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS34  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 99.06)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS33  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 96.52)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS84  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 111.76)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS32  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 93.98)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS36  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 104.14)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS86  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 116.84)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS35  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 101.60)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS85  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (398.78, 114.30)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS40  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 114.30)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS39  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 111.76)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS38  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 109.22)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS37  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 106.68)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS44  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 124.46)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS42  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 119.38)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS43  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 121.92)
ERROR(ORCAP-1628): Possible pin type conflict U1,VSS41  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (353.06, 116.84)
ERROR(ORCAP-1628): Possible pin type conflict U1,PLL_AVSS  Power Connected to Output
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (66.04, 71.12)
ERROR(ORCAP-1628): Possible pin type conflict U1,BS_JTAG_TRSTn  Output Connected to Power
                    RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (58.42, 134.62)
ERROR(ORCAP-1628): Possible pin type conflict U7,VSSQ  Power Connected to Output
                    RK3288_BOX_Ref, 10.Nand FLASH/eMMC/TF Card  (261.62, 254.00)
ERROR(ORCAP-1628): Possible pin type conflict U7,VSS  Power Connected to Output
因为自己遇到这样的错误不是一次两次了,但是每次解决后就没有去特意记下来,这次又要去网上这里问,哪里搜,还是没有得到答案,后面老办法,一个错误一个错误看,终于纠出报错的地方:    《RK3288_BOX_Ref, 11.RK3288 GPIO/POWER  (66.04, 71.12)
ERROR(ORCAP-1628): Possible pin type conflict U1,BS_JTAG_TRSTn  Output Connected to Power》就是这个地方,是输出属性,与属性为power(GND)的引脚接到了同一网络,所以出错,在此引脚上加上一个0R电阻即可解决,或者更改对应封装的这一引脚属性为Passive即可解决。
回帖(1)
h1654155282.9846
2019-2-22 12:50:14
ddddddddddddddddddddddddddd
举报
更多回帖
