嗨 - 我们没有任何电流信号发生器可以满足您的最小上升/下降时间1ns。
我们的PSG的典型上升/下降时间为6ns,而EXG / MXG-B的典型值为7ns。
如果你对上面提到的上升/下降时间没问题,那么N5172B可以满足其他特性。
如果您对其他规格有疑问,请在此处找到数据表:http://www.home.agilent.com/agilent/redirector.jspx?action =obs& nid = -536906709.3.00&amp ;lc = eng& cc =
US& ckey = 2163727& pubno = 5991-0039EN& ltype = LitStation& ctype = AGILENT_EDITORIAL我希望这有帮助 -
以上来自于谷歌翻译
以下为原文
Hi -
We do not have any current signal generators that will meet your minimum rise/fall times of 1ns.
Our PSG has a typical rise/fall time of 6ns, and our EXG/MXG-B has a typical of 7ns.
The other characteristics can be met with the N5172B, if you were okay with the mentioned rise/fall times.
The data sheet can be found here if you have questions about other specifications: http://www.home.agilent.com/agilent/redirector.jspx?action=obs&nid=-536906709.3.00&lc=eng&cc=US&ckey=2163727&pubno=5991-0039EN<ype=LitStation&ctype=AGILENT_EDITORIAL
I hope this helped -
如果您对其他规格有疑问,请在此处找到数据表:http://www.home.agilent.com/agilent/redirector.jspx?action =obs&amp; nid = -536906709.3.00&amp ;lc = eng&amp; cc =
US&amp; ckey = 2163727&amp; pubno = 5991-0039EN&amp; ltype = LitStation&amp; ctype = AGILENT_EDITORIAL我希望这有帮助 -
以上来自于谷歌翻译
以下为原文
Hi -
举报
