Cypress技术论坛
直播中
王禅
8年用户 219经验值
私信 关注
[问答]
太阳能控制器内置MPPT算法能移植到PSoC 1设备上吗?
基于CY8Celd04D01的CyPress充电控制器具有内置MPPT算法。有可能将该算法移植到PSoC 1设备上吗?使用这个装置有什么好处吗?
对不起,再次张贴问题,我想我最初张贴在错误的位置。
以上来自于百度翻译
     以下为原文
  The Cypress' charge controller based on CY8CLED04D01 has an in-built MPPT algorithmn. Is it possible to port that algorithm to a PSoC 1 device? Is there any advantage of using this device?
    Sorry for posting the question again, I think I posted initially in the wrong location.
回帖(3)
王琳
2019-2-20 11:31:18
不,你在这里,我回答了你的另一个线索:HTTP://www. CyPress?APP =论坛和ID ID=1573和;RID=73596
鲍勃
以上来自于百度翻译
     以下为原文
  No, you are right here, I answered one of your other threads here: http://www.cypress.com/?app=forum&id=1573&rID=73596
    Bob
举报
杨军
2019-2-20 11:44:45
HTTP://www. CyPress?COM/?DOCID=34455
这种注意是伴随着一个项目文件,用C写的。
你可以把它移植到你自己的HW设计中。
问候,Dana。
以上来自于百度翻译
     以下为原文
  http://www.cypress.com/?docID=34455
    This ap note is accompanied by a project file set, written in C.
    You could possibly port it to your own HW design.
    Regards, Dana.
举报
王建华
2019-2-20 12:00:32
除了核心之外,PowerPSoC还具有诸如滞环控制器、CSAT等附加电源外设(与PSoC 1内核-M8C相同)。在某种程度上,应该将代码移植到PSoC 1设备上,但必须使用外部组件。
赛普拉斯解决方案的关键优势在于它是一种用于电池充电和驱动LED的芯片解决方案。PowerPSoC有4个通道的电源外设,这些也可以用于LED驱动。因此,使用一个PoPPSoC设备,可以实现一个用于充电电池和驱动LED的单芯片解决方案。
你可以找到所有关于赛普拉斯的MPPT方案在链路-http://www.cypress.com/细节吗?RID=72393和源=页眉。
应用说明,Dana提到了所有的细节,这种解决方案随着固件。A链接iStTpp//wwwyCyPress?RID=39126
最好的问候
安舒尔
以上来自于百度翻译
     以下为原文
  PowerPSoC has additional power peripherals like hysteretic controllers, CSA etc in addition to the core (which is same as the PSoC 1 core - M8C). Indeally, it should be possible to port the code to a PSoC 1 device but you will have to use external components.
    The key advantage of Cypress' solution is that it is is a single chip solution for battery charging and driving LEDs. PowerPSoC has 4 channels of the power peripherals, these can be used for LED driving as well. So, with one PowerPSoC device you can implement a single chip solution for charging the battery and driving LEDs.
    You can find all the details about the Cypress's MPPT solution at the link - http://www.cypress.com/?rid=72393&source=header
    The Application Note that Dana mentioned has all the details about this solution along with the firmware. The AN link is http://www.cypress.com/?rID=39126
    Best Regards
    Anshul
举报
更多回帖
