赛灵思
直播中
王俊
8年用户 177经验值
私信 关注
[问答]
ISIM tcl命令行延伸到PC屏幕右侧太远
我的问题:
我创建了tcl文件以在ISIM中运行模拟,当我在整个运行时强制信号进行多级更改时,命令行变得太长(在屏幕右侧)。
有没有办法在ISIM继续执行的命令行上添加一行更改,就好像它执行1命令行一样?
例:
isim force add RAM_wr 0 -radix bin -time 0 -value 1 -radix bin -time 800ns -value 0 -radix bin -time 820ns -value 1 -radix bin -time 1300ns -value 0 -radix bin -time 1320ns -value 1
-radix bin -time 2050ns -value 0 -radix bin -time 2070ns
感谢帮助。
以上来自于谷歌翻译
以下为原文
My question:
I create tcl file to run simulation in ISIM, the command lines is getting too long (to the right of the screen) when I force signal to many level changes during the whole run time. Is there a way to append a line changing on the command line that ISIM continues to execute as if it executes 1 command line?
Example:
isim force add RAM_wr 0 -radix bin -time 0 -value 1 -radix bin -time 800ns -value 0 -radix bin -time 820ns -value 1 -radix bin -time 1300ns -value 0 -radix bin -time 1320ns -value 1 -radix bin -time 2050ns -value 0 -radix bin -time 2070ns
Thanks for help.
回帖(1)
刘秀兰
2019-2-19 09:47:39
这些是开关选项..您需要在ISIM属性中选择isim开关。
请使用属性,然后查看命令行.Regards,Vishal
以上来自于谷歌翻译
以下为原文
these are switch options.. you will need to select isim switches in ISIM properties. Please play with properties and then see the command line.
Regards,
Vishal
举报
更多回帖
