单片机学习小组
直播中
武文嘉
8年用户 180经验值
私信 关注
C8051F340采样6路电压值问题
以下是Silicon Laboratories提供的example。 即依次对P2.0、P2.1、P2.2、P2.3、P2.5、P2.6的电压值进行采样
,这样的话为什么在Port_Init()里把P2口配置为P2MDIN &= ~0x3F?不应该是P2MDIN &= ~0x6F吗??板子上的P2.5
连接的是一电位器,采取P2MDIN &= ~0x3F的配置扭动电位器时P2.6(P2.6是悬空的)的值不会随电位器变化而变化
;而改为P2MDIN &= ~0x6F后扭动电位器时P2.6的值也会随电位器的变化而变化??这是为什么呢??麻烦各位给看
看这是怎么个情况!!
// F34x_ADC0_ExternalInput_Mux.c
// Copyright 2005 Silicon Laboratories, Inc.
// http://www.silabs.com
// This code example illustrates using the internal analog multiplexer to
// measure analog voltages on up to 8 different analog inputs.  Results are
// printed to a PC terminal program via the UART.
// The inputs are sequentially scanned, beginning with input 0 (P2.0), up
// to input number -1 based on the values in .
// ADC Settling Time Requirements, Sampling Rate:
// The total sample time per input is comprised of an input setting time
// (Tsettle), followed by a conversion time (Tconvert):
// Tsample  = Tsettle + Tconvert
// Settling and conversion times may overlap, as the ADC holds the value once
// conversion begins.  This program takes advantage of this to increase the
// settling time above the minimum required.  In other words, when
// converting the value from analog input Ain(n), the input mux is switched
// over to the next input Ain(n+1) to begin settling.
// |---Settling Ain(n)---|=Conversion Ain(n)=|
//                       |---Settling Ain(n+1)---|=Conversion Ain(n+1)=|
//                                               |---Settling Ain(n+2)---|
// ISR:  Timer 2         ^                       ^                       ^
// ISR:  ADC0                                ^                         ^
// The ADC input voltage must be allowed adequate time to settle before the
// conversion is made.  This settling depends on the external source
// impedance, internal mux impedance, and internal capacitance.
// Settling time is given by:
//                   | 2^n |
//    Tsettle =   ln | --- | * Rtotal * Csample
//                   | SA  |
// In this application, assume a 100kohm potentiometer as the voltage divider.
// The expression evaluates to:
//                   | 2^12 |
//    Tsettle =   ln | ---- | * 105e3 * 10e-12 = 10.2uS
//                   | 0.25 |
// In addition, one must allow at least 1.5 us after changing analog MUX
// inputs or PGA settings.  The settling time in this example, then, is
// dictated by the large external source resistance.
// The conversion is 16 periods of the SAR clock.  At 2.5 MHz,
// this time is 16 * 400nS = 6.4 uS.
// Tsample, minimum  = Tsettle + Tconvert
//                   = 10.2uS + 6.4uS
//                   = 16.6 uS
// Timer2 is set to change the MUX input and start a conversion every 20 us.
// General:
// The system is clocked using the internal 12MHz oscillator. Results are
// printed to the UART from a loop with the rate set by a delay based on
// Timer0. This loop periodically reads the ADC value from a global array,
// The ADC makes repeated measurements at 20 us intervals based on Timer2.
// The end of each ADC conversion initiates an interrupt which calls an
// averaging function. samples are averaged, then the Result
// values updated.
// For each power of 4 of , you gain 1 bit of effective resolution.
// For example, = 256 gain you 4 bits of resolution: 4^4 = 256.
// The ADC input multiplexer is set for a single-ended input.  The example
// sequentially scans through the inputs, starting at P2.0.
// inputs are read.  The amplifier is set for unity gain so a voltage range of
// 0 to Vref (2.43V) may be measured.  Although voltages up to Vdd may be
// applied without damaging the device, only the range 0 to Vref may be
// measured by the ADC.
// A 100 kohm potentiometer may be connected as a voltage divider between
// VREF and AGND as shown below:
//         o| AGND ----|
//         o| VREF ----|<-|
//         o| P2.x     |  |
//         o|    |        |
//         o|     --------
//         o|
//         o|
//         o|
// How To Test:
// 1) Download code to a 'F34x device that is connected to a UART transceiver
// 2) Verify the TX and RX jumpers are populated on J3.
// 3) Connect a serial cable from the DB9 connector to a PC
// 4) On the PC, open HyperTerminal (or any other terminal program) and connect
//    to the COM port at and 8-N-1
// 5) Connect a variable voltage source (between 0 and Vref) to the Port2 pins,
//    or a potentiometer voltage divider as shown above.
// 6) HyperTerminal will print the voltages measured by the device if
//    everything is working properly.  Note that some of the analog inputs are
//    floating and will return nonzero values.
// FID:            34X000092
// Target:         C8051F34x
// Tool chain:     Keil C51 7.50 / Keil EVAL C51
// Command Line:   None
// Release 1.0
//    -Initial Revision (SM / TP)
//    -19 OCT 2006
// Includes
#include                  // SFR declarations
#include
// 16-bit SFR Definitions for 'F34x
sfr16 TMR2RL = 0xCA;                   // Timer2 reload value
sfr16 TMR2 = 0xCC;                     // Timer2 counter
sfr16 ADC0 = 0xBD;                     // 10-bit ADC0 result
// Global CONSTANTS
#define SYSCLK        12000000         // SYSCLK frequency in Hz
#define BAUDRATE      115200           // Baud rate of UART in bps
#define ANALOG_INPUTS 6                // Number of AIN pins to measure,
                                       // skipping the UART0 pins
#define INT_DEC       256              // Integrate and decimate ratio
#define TIMER0_RELOAD_HIGH  0          // Timer0 High register
#define TIMER0_RELOAD_LOW 255          // Timer0 Low register
// Function PROTOTYPES
void Oscillator_Init (void);
void Port_Init (void);
void Timer2_Init(void);
void ADC0_Init(void);
void UART0_Init (void);
void Timer0_wait(int ms);
// Global Variables
long RESULT[ANALOG_INPUTS];            // ADC0 decimated value, one for each
                                       // analog input
// The values are the values to be written to the AMX0P
// register to select the P2. port pins.
// For the 'F340, the AMX0P settings correspond to the following port pins:
//    AMX0P      Port Pin
//    0x00         P2.0
//    0x01         P2.1
//    0x02         P2.2
//    0x03         P2.3
//    0x04         P2.5
//    0x05         P2.6
unsigned char idata PIN_TABLE[ANALOG_INPUTS] = {0,1,2,3,5,6};
unsigned char idata PIN_MUX_TABLE[ANALOG_INPUTS] = {0,1,2,3,4,5};
unsigned char AMUX_INPUT = 0;          // Index of analog MUX inputs
// MAIN Routine
void main (void)
   unsigned char i;
   unsigned long measurement;
   PCA0MD &= ~0x40;                    // WDTE = 0 (clear watchdog timer
                                       // enable)
   Oscillator_Init ();                 // Initialize system clock to
                                       // 12MHz
   Port_Init ();                       // Initialize cros***ar and GPIO
   Timer2_Init();                      // Init Timer2 to generate
                                       // overflows to trigger ADC
   UART0_Init();                       // Initialize UART0 for printf's
   ADC0_Init();                        // Initialize ADC0
   EA = 1;                             // Enable global interrupts
   while (1)
      EA = 0;                          // Disable interrupts
      printf("f");
      for(i = 0; i < ANALOG_INPUTS; i++)
         // The 10-bit ADC value is averaged across INT_DEC measurements.
         // The result is then stored in RESULT, and is right-justified
         // The measured voltage applied to the port pins is then:
         //                           Vref (mV)
         //   measurement (mV) =   --------------- * Result (bits)
         //                        (2^10)-1 (bits)
         measurement =  RESULT * 2430 / 1023;
         printf("P2.%bu voltage: %4ld mVn",PIN_TABLE,measurement);
      EA = 1;                          // Re-enable interrupts
      Timer0_wait(25);                  // Wait before displaying new values
// Initialization Subroutines
// SYSCLK_Init
// Return Value : None
// Parameters   : None
// This routine initializes the system clock to use the internal 12MHz
// oscillator as its clock source.  Also enables missing clock detector reset.
   OSCICN = 0x83;                      // Configure internal oscillator for
                                       // its highest frequency
   RSTSRC = 0x04;                      // Enable missing clock detector
// Port_Init
// Configure the Cros***ar and GPIO ports.
// P0.4 - UART TX (push-pull)
// P0.5 - UART RX
// P1.5 - analog (VREF)
// P2.0 - analog input (ADC0)
// P2.1 - analog input (ADC0)
// P2.2 - analog input (ADC0)
// P2.3 - analog input (ADC0)
// P2.5 - analog input (ADC0)
// P2.6 - analog input (ADC0)
   P2SKIP = 0x3F;                      // Skip all analog pins
   XBR0 = 0x01;                        // UART0 TX and RX pins enabled
   XBR1 = 0x40;                        // Enable cros***ar and weak pull-ups
   P0MDOUT |= 0x10;                    // Enable TX0 as a push-pull output
   P1MDIN &= ~0x20;                    // P1.5 in analog mode
   P2MDIN &= ~0x3F;                    // Set desired pins as analog inputs
// Timer2_Init
// Configure Timer2 to 16-bit auto-reload and generate an interrupt at 10 us
// intervals.  Timer2 overflows automatically triggers ADC0 conversion.
void Timer2_Init (void)
   TMR2CN = 0x00;                      // Stop Timer2; Clear TF2;
                                       // use SYSCLK as timebase, 16-bit
                                       // auto-reload
   CKCON |= 0x10;                      // Select SYSCLK for timer 2 source
   TMR2RL = 65535 - (SYSCLK / 10000);  // Init reload value for 10 us
   TMR2 = 0xffff;                      // Set to reload immediately
   ET2 = 1;                            // Enable Timer2 interrupts
   TR2 = 1;                            // Start Timer2
// ADC0_Init
// Configures ADC0 to make single-ended analog measurements on Port 2 according
// to the values of and .
void ADC0_Init (void)
   ADC0CN = 0x02;                      // ADC0 disabled, normal tracking,
                                       // conversion triggered on TMR2 overflow
   REF0CN = 0x03;                      // Enable internal VREF
   AMX0P = PIN_MUX_TABLE[0];           // ADC0 initial positive input = P2.0
   AMX0N = 0x1F;                       // ADC0 negative input = GND
                                       // i.e., single ended mode
   ADC0CF = ((SYSCLK/3000000)-1)<<3;   // Set SAR clock to 3MHz
   ADC0CF |= 0x00;                     // Right-justify results
   EIE1 |= 0x08;                       // Enable ADC0 EOC interrupt
   AD0EN = 1;                          // Enable ADC0
// UART0_Init
// Configure the UART0 using Timer1, for and 8-N-1.
   SCON0 = 0x10;                       // SCON0: 8-bit variable bit rate
                                       //        level of STOP bit is ignored
                                       //        RX enabled
                                       //        ninth bits are zeros
                                       //        clear RI0 and TI0 bits
   if (SYSCLK/BAUDRATE/2/256 < 1) {
      TH1 = -(SYSCLK/BAUDRATE/2);
      CKCON |=  0x08;                  // T1M = 1; SCA1:0 = xx
   } else if (SYSCLK/BAUDRATE/2/256 < 4) {
      TH1 = -(SYSCLK/BAUDRATE/2/4);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 01
      CKCON |=  0x01;
   } else if (SYSCLK/BAUDRATE/2/256 < 12) {
      TH1 = -(SYSCLK/BAUDRATE/2/12);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 00
   } else if (SYSCLK/BAUDRATE/2/256 < 48) {
      TH1 = -(SYSCLK/BAUDRATE/2/48);
      CKCON &= ~0x0B;                  // T1M = 0; SCA1:0 = 10
      CKCON |=  0x02;
   } else {
      while (1);                       // Error.  Unsupported baud rate
   TL1 = TH1;                          // Init Timer1
   TMOD &= ~0xF0;                      // TMOD: timer 1 in 8-bit autoreload
   TMOD |=  0x20;
   TR1 = 1;                            // START Timer1
   TI0 = 1;                            // Indicate TX0 ready
// Interrupt Service Routines
// Timer2_ISR
// This routine changes to the next Analog MUX input whenever Timer2 overflows
// for the next ADC sample.  This allows the ADC to begin setting on the new
// input while converting the old input.
void Timer2_ISR (void) interrupt 5
   TF2H = 0;                           // Clear Timer2 interrupt flag
   // Set up the AMUX for the next ADC input
   // ADC0 positive input = P2.
   if (AMUX_INPUT == (ANALOG_INPUTS - 1))
   else
      AMX0P = PIN_MUX_TABLE[AMUX_INPUT+1];
// ADC0_ISR
// This ISR averages samples for each analog MUX input then prints
// the results to the terminal.  The ISR is called after each ADC conversion,
// which is triggered by Timer2.
void ADC0_ISR (void) interrupt 10
   static unsigned int_dec = INT_DEC;  // Integrate/decimate counter
                                       // A new result is posted when
                                       // int_dec is 0
   // Integrate accumulator for the ADC samples from input pins
   static long accumulator[ANALOG_INPUTS] = 0x00000000;
   unsigned char i;                    // Loop counter
   AD0INT = 0;                         // Clear ADC conversion complete
                                       // overflow
   accumulator[AMUX_INPUT] += ADC0;    // Read the ADC value and add it to the
                                       // running total
   // Reset sample counter and if the final input was
   // just read
   if(AMUX_INPUT == (ANALOG_INPUTS - 1))
      int_dec--;                       // Update decimation counter
                                       // when the last of the analog inputs
                                       // is sampled
      if (int_dec == 0)                // If zero, then post the averaged
      {                                // results
         int_dec = INT_DEC;            // Reset counter
         // Copy each averaged ADC0 value into the RESULT array
            // Copy averaged values into RESULT
            RESULT = accumulator / int_dec;
            // Reset accumulators
            accumulator = 0x00000000;
      AMUX_INPUT = 0;                  // Reset input index back to P2.0
   // Otherwise, increment the AMUX channel counter
   else
      AMUX_INPUT++;                    // Step to the next analog mux input
// Support Subroutines
// Timer0_Init
// Parameters   :
//   1) int ms - number of milliseconds to wait
//                        range is positive range of an int: 0 to 32767
// This function configures the Timer0 as a 16-bit timer, interrupt enabled.
// Using the internal osc. at 12MHz with a prescaler of 1:8 and reloading the
// T0 registers with TIMER0_RELOAD_HIGH/LOW, it will wait for
// milliseconds.
// Note: The Timer0 uses a 1:12 prescaler
   TH0 = TIMER0_RELOAD_HIGH;           // Init Timer0 High register
   TL0 = TIMER0_RELOAD_LOW ;           // Init Timer0 Low register
   TMOD |= 0x01;                       // Timer0 in 16-bit mode
   CKCON &= 0xFC;                      // Timer0 uses a 1:12 prescaler
   TR0  = 1;                           // Timer0 ON
   while(ms)
      TF0 = 0;                         // Clear flag to initialize
      while(!TF0);                     // Wait until timer overflows
      ms--;                            // Decrement ms
   TR0 = 0;                            // Timer0 OFF
// End Of File
回帖(3)
王鑫
2019-2-15 07:43:58
P2MDIN 是做什么用的?
举报
白桦
2019-2-15 07:49:30
回复【2楼】发烧友:
把P2的的6个采样引脚(P2.0、P2.1、P2.2、P2.3、P2.5、P2.6)配置为模拟输入。
举报
冯媛媛
2019-2-15 08:05:17
看你的描述,应该是对应位为0,则代表设置为模拟输入。
P2MDIN &= ~0x3F,则是设置P2.0~5
P2MDIN &= ~0x6F,则设置的是P2.0~3,P2.5,P2.6
当设置为P2MDIN &= ~0x6F时P2.6就被设置为模拟输入了,如果IO脚电平变化的话,应该就能采集到了。
举报
更多回帖
