| R16 android4.4 常见问题参考手册 目录 [隐藏] 1 R16 android4.4 常见问题 1.1 一)在内核中添加spi驱动 1.2 二)以太网不能用 1.3 三)默认勾选使用以太网 R16 android4.4 常见问题 一)在内核中添加spi驱动 $cd lichee/linux-3.4 $make ARCH=arm menuconfig $lunch astar_parrot-tina $make kernel_menuconfig Device Drivers ---> SPI support ---> <*> User mode SPI device driver support 修改 lichee/tools/pack/chips/sun8iw5p1/configs/evb-30/sys_config.fex [spi_board0] modalias = "at25df641" sflash_size = 32 max_speed_hz = 50000000 bus_num = 0 chip_select = 0 mode = 0 修改成 [spi_board0] modalias = "spidev" sflash_size = 32 max_speed_hz = 50000000 bus_num = 0 chip_select = 0 mode = 0 二)以太网不能用 在内核增加驱动 $make ARCH=arm menuconfig Device Drivers ---> Network device support ---> USB Network Adapters ---> <*> Multi-purpose USB Networking Frameworksuch as cable modems) <*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices 三)默认勾选使用以太网 1)在frameworksbasepackagesSettingsProviderresvaluesdefault.xml 2)在frameworksbasepackagesSettingsProvidersrccomandroidproviderssettingsDatabaseHelper.java 添加 loadBooleanSetting(stmt, Settings.Global.ETHERNET_CONF, R.bool.def_ethernet_conf) loadStringSetting(stmt, Settings.Global.ETHERNET_IFNAME, R.string.def_ethernet_ifname) |
举报
更多回帖
