嘿,所有的程序设备选项都是灰色的,但IDE是“看到”PIC(见下文)使用ICD3…有什么想法吗?昨天工作得很好…重新启动,重新启动…ICD3/PIC细节。连接到MPLAB ICD 3……当前加载的固件在ICD 3固件套件版本…01.4614固件类型……PIC18FEXPLER到目标
电源启用- VDD=3.750000伏。目标设备PIC18F420找到。设备ID修订= 7MPLAB Vrices产品版本:MPLAB X IDE V3.50Java:1.8 0J91;Java热点(TM)64位服务器VM 25.91-B14Run
time:Java(TM)SE运行时环境1.80y91-B14系统:运行在X8664上的Mac OS X版本101.6;UTF-8;EN(MPLAB)用户目录:/用户/ [用户名] /库/应用支持/MPLABUIDID/DEV/V3.50CAC目录:/用户/ [用户名] /库/缓存/ MPLABIDID/DEV/V3.50/VAR克里斯
以上来自于百度翻译
以下为原文
Hey all,
The Program Device Options are all greyed out, but the IDE is "seeing" the PIC (see below) using the ICD3... any ideas? worked fine yesterday... restarted, rebooted...
ICD3 / PIC Details.
Connecting to MPLAB ICD 3...
Currently loaded firmware on ICD 3
Firmware Suite Version.....01.46.14
Firmware type..............PIC18F
Programmer to target power is enabled - VDD = 3.750000 volts.
Target device PIC18F4420 found.
Device ID Revision = 7
MPLAB Verisons
Product Version: MPLAB X IDE v3.50
Java: 1.8.0_91; Java HotSpot(TM) 64-Bit Server VM 25.91-b14
Runtime: Java(TM) SE Runtime Environment 1.8.0_91-b14
System: Mac OS X version 10.11.6 running on x86_64; UTF-8; en (mplab)
User directory: /Users/[username]/Library/Application Support/mplab_ide/dev/v3.50
Cache directory: /Users/[username]/Library/Caches/mplab_ide/dev/v3.50/var
Chris
