对。PSoC 3和PSoC 5的资源和CPU小时功率允许用户开发音频信号。检查PSoC Creator软件中的I2S组件。你可以在通信类日志中找到它。集成的IC间声音总线(I2S)组件仅在主模式下运行。它还工作在两个方向:作为发射机(Tx)和接收机(RX)。Tx和RX的数据是独立的字节流。字节流首先用最重要的字节和第一个字的位7中的最高有效位来填充。每个样本所使用的字节数(左或右通道的样本)是保存样本的最小字节数。
以上来自于百度翻译
以下为原文
Yes. the resource and CPU hourse power in PSoC 3 and PSoC 5 allows users to develop audio signals. Check out the I2S comonent in PSoC Creator software. You can find it under Communication categlog. The Integrated Inter-IC Sound Bus (I2S) component operates in Master mode only. It also operates in two directions: as a transmitter (Tx) and a receiver (Rx). The data for Tx and Rx are independent byte streams. The byte streams are packed with the most significant byte first and
the most significant bit in bit 7 of the first word. The number of bytes used for each sample (a sample for the left or right channel) is the minimum number of bytes to hold a sample.
以上来自于百度翻译
以下为原文
举报
