是德科技
直播中
李四民
8年用户 144经验值
私信 关注
[问答]
使用FEM进行带状线模拟收到错误
嗨,我正在尝试用FEM模拟带状线。
我经历了一个教程。
但是,我收到以下错误。
IndexError:列表分配索引超出范围Traceback(最近一次调用最后一次):文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第654行,在主文件“/ software / ads-2011_05_400 / fem_scripts / sim中。
py“,第532行,在import_settings_and_simulate proj.ads_import()文件”/home/ssaxena4/Research/HSpeed_Wireline/FEM_sims/simulation/FEM_sims_lib/dstrip_1in/layout/emSetup_FEM/proj.py“,第233行,在ads_import中波导.faces =
[(part,part.faces()[0])] IndexError:列表赋值索引超出范围文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第658行,在main()中simObject.import_settings_and_simulate(stop_after_project_creation)
)self.openOrCreateEMProProject(proj)文件“/software/ads-2011_05_400/fem_scripts/sim.py”,第388行,在openOrCreateEMProProject中,模拟中止。
有人可以帮忙调试问题吗?
我试图模拟一个例子,运行正常。
但是,我创建的带状线是一个问题。
谢谢您的帮助。
SAURABH
以上来自于谷歌翻译
     以下为原文
  Hi,
I am trying to simulate a stripline with FEM. I went through a tutorial. However, I getting the following error.
IndexError: list assignment index out of range
Traceback (most recent call last):
      File "/software/ads-2011_05_400/fem_scripts/sim.py", line 654, in main
  File "/software/ads-2011_05_400/fem_scripts/sim.py", line 532, in import_settings_and_simulate
    proj.ads_import()
  File "/home/ssaxena4/Research/HSpeed_Wireline/FEM_sims/simulation/FEM_sims_lib/dstrip_1in/layout/emSetup_FEM/proj.py", line 233, in ads_import
    waveguide.faces=[(part,part.faces()[0])]
  File "/software/ads-2011_05_400/fem_scripts/sim.py", line 658, in
main()
  File "/software/ads-2011_05_400/fem_scripts/sim.py", line 388, in openOrCreateEMProProject
And the simulation gets aborted. Can someone help tp debug the problem? I tried to simulate an example and that runs fine. But, the stripline which I created is an issue.
Thanks for the help.
Saurabh
回帖(2)
李建军
2019-2-12 09:06:31
嗨,问题似乎与端口定义有关,因此您可以尝试以下操作: - 使用不同的设置重新输入端口,例如
尝试将校准设置为“无” - 重新输入具有与布局不同连接点的端口或者,请联系Agilent支持以获取有关问题的帮助。
以上来自于谷歌翻译
     以下为原文
  Hi,
The problem seems to be related to the port definition, so you can try the following:
- re-enter the ports with a different setup, e.g. try setting calibration to 'None'
- re-enter the ports with different connection points to the layout
Alternatively contact Agilent support to get help with the problem.
举报
李四民
2019-2-12 09:14:53
谢谢您的帮助。
从uW测试台开始,我是差分端口。
在FEM中,似乎我需要使用传统的端口定义,然后可以使用TML校准。
谢谢。
SAURABH
以上来自于谷歌翻译
     以下为原文
  Thanks for the help. I was differential ports before from uW test bench. In FEM, it appears I need to use conventional ports definition and then TML calibration can be used.
Thanks.
Saurabh
举报
更多回帖
