是德科技
直播中
刘玉梅
7年用户 213经验值
私信 关注
[问答]
TestExec SL 7.1.2项目怎么迁移
大家好!
我一直在使用TestExec SL 4.0和TS5400系统与Windows NT。
我知道这很老了!
这就是为什么我决定将我的系统更新为Win 7.因此我将不得不安装带有TS5000的TestExec SL 7.1.2版本。
你知道,这是一个巨大的变化。
那么,有人已经做过这项工作,请给我任何建议,提示或建议吗?
我担心的是某些乐器或类似的因为Dlls等而无法正常工作......我想为这个挑战做好准备...... Tkanks!
以上来自于谷歌翻译
     以下为原文
  Hello everyone!
I've been using TestExec SL 4.0 and TS5400 system with Windows NT. It is very old I know! That's why I've decided to update my system to Win 7. Consequently I will have to install the TestExec SL 7.1.2 version with TS5000. You know, It is a tremendous change.
So, Would anybody have already made this job to provide me any suggestions, hints or advises please?
My concern is about some instrument or something like that doesnt work properly because of Dlls etc...
I would like to be ready for this challenge...
Tkanks!
回帖(3)
邢东
2019-1-28 10:28:42
嗨Tsjabrantes,我能理解你对此的担忧。
您可能需要检查的事项是: - 1)您使用的所有操作都是由Agilent开发的吗?
如果是,新版本应该能够正常运行。
2)如果你的公司有一些行动,我们可能需要试试它是否适用于Win 7和TestExec SL 7.我建议: - 1)你有硬盘的备份,然后再将它们更改为
Win7&
TestExec SL 7 2)如果您遇到问题,请联系一直支持您的本地AE / AE。
当然,你当然可以联系我们。
我不能保证整个过程会顺利运行,因为它有太多的变数。
尽管如此,TestExec SL 7已尽力兼容并保留以前开发的所有操作。
P / S:当前版本的TestExec SL为7.1.3,与TS5000相同。
谢谢。
此致,辛西娅
以上来自于谷歌翻译
     以下为原文
  Hi Tsjabrantes,
I can understand your worry about this.
Things you might need to check are:-
1) Are all the actions that you are using are developed by Agilent? If yes, the newer version should be able to run without problem.
2) If there are some actions that are developed by your company, we might need to try out if it works in Win 7 and TestExec SL 7.
I would suggest that:-
1) You have a backup of your hardisk before changing them to Win7 & TestExec SL 7
2) Contact the local AE/ AE that has been supporting you all the while to standby in case you get into problems. And of course, you can certainly contact us.
I cannot guaranteed the whole process will run smoothly as it has too much variables. Nonetheless, TestExec SL 7 has tried the best to be compatible and retaining all the actions previously developed.
P/S: The current version of TestExec SL is 7.1.3, same for TS5000.
Thanks.
Regards,
Cynthia
举报
刘玉梅
2019-1-28 10:48:06
如果是,新版本应该能够正常运行。
辛西娅你好!
首先感谢您的反馈,但我有一个疑问: - TestExec SL 7.1.2运行Win 7 32或64位吗?
如果我用TS5400Sériell和VXI运行它有什么问题吗?
谢谢!编辑:Tsjabrantes于2013年12月20日上午6:25
以上来自于谷歌翻译
     以下为原文
  Hello Cynthia!
First of all thanks for your feedback, but I have one doubt: - Does the TestExec SL 7.1.2 run with Win 7 32 or 64 bits?
Is there any problem if I run it with the TS5400 Série ll and the VXI?
Thanks!
Edited by: Tsjabrantes on Dec 20, 2013 6:25 AM
举报
邢东
2019-1-28 10:54:02
引用: qiwendianzi 发表于 2019-1-28 10:48
辛西娅你好!
Hi Tsjabrantes,TestExec SL 7能够以32位和64位运行。
唯一的问题是VXI Plug& Play drviers无法安装在64位驱动程序中。
但是,如果TS-5000软件检测到您的操作系统为64位,它将自动将所需的VXI模块DLL复制到正确的目标位置。
这将使所有测试计划工作。
请注意,即使您的操作系统是64位,TestExec SL仍然在32位环境中运行。
因此,VXI DLL没有问题。
谢谢。
此致,辛西娅
以上来自于谷歌翻译
     以下为原文
  Hi Tsjabrantes,
TestExec SL 7 is able to run in both 32 bit and 64 bit. The only problem was that VXI Plug&Play drviers are not able to be installed in 64-bit drivers. However, if TS-5000 software has detected your operating system to be 64 bit, it will automatically copy the needed DLL for VXI Modules to the correct destination. This will makes all the testplans to work.
Do note that, even though your operating system is 64 bit, TestExec SL is still running in 32 bit environment. Thus, the VXI DLLs has no issue.
Thanks.
Regards,
Cynthia
举报
更多回帖
