Cypress技术论坛
直播中
陈晓晨
8年用户 165经验值
私信 关注
[问答]
无法在PSoC Creator 1.0 Beta 2.0(1.0.0.4248)中打开项目
嗨,大家好,
我试图在PSoC创建者1 beta 2(1.0.0.4248)中打开我的旧项目。
但它显示
错误:PRJ.M0552:无法打开项目“Project”:(XML文档中存在错误(1659, 3))。处理错误并重试。
如何纠正?我认为这可能是因为PSoC Creator版本的项目创建与beta 2不同,但是如何检查创建哪个版本的项目呢??
还是其他原因导致了这个错误?
请帮助。
RGDS,
雅杰
以上来自于百度翻译
     以下为原文
  Hi all,
    I tried to open my old project in PSoC Creator 1.0 Beta 2.0 (1.0.0.4248).
    But it shows
    Error: prj.M0052: Unable to open the project "Project": (There is an error in XML document (1659, 3).). Address the error and try again.
    how to rectify that? I think it may be due to PSoC Creator version on which project created is different from the Beta 2.0 , but how to check in which version project is created??
    or some other reason is there for this error?
    Kindly help.
    rgds,
    yaj
回帖(2)
王建华
2019-1-25 14:45:42
有没有理由不运行PSoC创建者1 beta 5?beta 2现在已经很旧了,很多东西都被改变了。
-博比
以上来自于百度翻译
     以下为原文
  Is there a reason you are not running PSoC Creator 1.0 Beta 5?  The Beta 2 is very old now, and many things have been changed.
    -Bobby
举报
马昱
2019-1-25 14:56:33
你好,
建议在项目中使用最新版本的创建者。
有一种方法可以通过执行下列步骤来确定项目上次生成的版本:
1)从存储的位置打开项目文件夹并打开.Cysn文件夹。
2)在Cysn文件夹中,有一个类型为“未知项目类型”的项目文件。这有一个具有芯片形状的图标。
3)右击此图标并使用记事本打开它。
4)滚动到底部。最后一行但第四行显示了BooToI组件的版本。
例如,如果& t;BooToTebug V=“CythBooToV2O0”//gt;那么它是beta 5版本(CythBooo=版本2)。
较老版本的创建者拥有较旧版本的组件。
当做,
高塔姆
以上来自于百度翻译
     以下为原文
  Hi,
    It is advisable to use latest version of Creator in your project.
    There is a way to determine the version in which the project was last built by doing the following:
    1) Open the project folder from the location in which it is stored and open the .cydsn folder.
    2) In the .cydsn folder, there is a project file which is of type "Unknown Project Type". This has an icon with the shape of a chip.
    3) Right-click on this icon and open it using notepad.
    4) Scroll to the bottom. The last but 4th line shows the version of the boot_component.
    For example, if , then it is Beta 5 version(cy_boot = version 2.0).
    Older version of creator had older version of components.
    Regards,
    Gautam
举报
更多回帖
