是德科技
直播中
陈敏
7年用户 1294经验值
私信 关注
[问答]
数据仅以灰度捕获
我正在使用Agilent Data Capture 4.3.0和我的MSO-X 3024A。
我上周在格式化计算机之前没有遇到这个问题,但现在除了灰度以外,我无法从我的示波器中获取任何图像。
它必须是我的示波器上的新版数据捕获软件或更新的固件。
上周两者都被取代了,所以我不能再将其缩小了。
我用谷歌搜索,查看了数据捕获帮助,并搜索了这个论坛
我找不到除了“编写你自己的代码”之外的任何东西,这不是一个好的解决方案。
我没有时间这样做,特别是考虑到已经有一些东西可以完全满足我的需要。
附上一个例子。编辑:bandtank于2013年9月16日上午12:59
以上来自于谷歌翻译
     以下为原文
  I'm using Agilent Data Capture 4.3.0 with my MSO-X 3024A. I didn't have this problem last week before I formatted my computer, but now I can't get any images off of my scope in anything but grayscale. It must be the new version of the data capture software or the updated firmware on my scope. Both were replaced last week, so I can't narrow it down anymore than that unfortunately.
I googled, looked through the data capture help, and searched this forum. I couldn't find anything other than "write your own code" which isn't a good solution. I don't have time to do that especially considering there's already something available to do exactly what I need.
An example is attached.
Edited by: bandtank on Sep 16, 2013 12:59 AM
附件
回帖(2)
王坤
2019-1-22 16:14:05
建立连接后,按“仪器>您的仪器”将调用一个对话框,您可以选择要保存的图像类型。
取消选中“反转”和“灰度”以获得彩色版本。
以上来自于谷歌翻译
     以下为原文
  After a connection has been made, pressing "Instrument > Your instrument" will invoke a dialog that lets you select what type of image to save.  Uncheck "Invert" and "Grayscale" to get the colored version.
举报
王坤
2019-1-22 16:20:07
建立连接后,按“仪器>您的仪器”。
这将调用一个对话框,让您选择要捕获的图像类型。
取消选中“灰度”。
以上来自于谷歌翻译
     以下为原文
  After a connection has been made, press "Instrument > Your instrument".  This will invoke a dialog which let's you select what type of image to capture.  Uncheck "grayscale".
举报
更多回帖
