是德科技
直播中
李剑
8年用户 150经验值
私信 关注
[问答]
混频器噪声系数低IF频率测量
大家好,我有N8973 NFA,需要测量混音器(下变频器)的噪声系数。
RF为700至900 MHz。
IF为10 -100 MHz。
我需要测量上边带和下边带。
我也需要在温度范围内这样做。
我将使用ESG或MXG信号发生器作为LO源。
我需要将数据作为IF频率的函数呈现(四条曲线,RF = 700,900 MHz,LO swpet作为上部和下部)。
由于IF频率,滤波是绝对必须的。
我有以下想法:1)双边带测量固定LO。
无需RF滤波器。
在LO上使用带通滤波器。
如果需要,打破IF频段,可以使用低通滤波器来抑制LO信号。
问题是我需要的数据仅为700和900 MHz,但IF每10 MHz(或10点)步进一次。
因此,我需要40次校准和测量。
2)固定射频。
我可以在RF上设置带通滤波器(BW 5%或35到45 MHz),这样4 MHz是平坦的,信号在20 MHz偏移时下降20 dB(我意识到我将无法测量10 MHz)
我可以在IF上使用低通滤波器,在这种情况下我只需要四次校准和测量。
NFA仅具有固定的LO /扫频IF或扫频LO /固定IF模式。
不确定如何设置NFA。
(我确实打电话到呼叫中心,但我想我还是会问这里)。
任何评论(赞成,赞成)或新想法都会很棒。
Michael J. Virostko美国马萨诸塞州韦斯特福德综合设备技术公司首席产品应用工程师
以上来自于谷歌翻译
     以下为原文
  Hello All,
  I have a N8973 NFA and need to measure the noise figure on a mixer (downconverter).  The RF is 700 to 900 MHz.  The IF is 10 -100 MHz.  I need to measure both the upper and lower sideband.  I also need to do this over temperature. I will be using a ESG or MXG signal generator for the LO source.  I need the data to be presented as a function of IF frequencies (four curves,  RF = 700, 900 MHz,  LO swpet as both the upper and lower).
  Filtering is an absolute must due to the IF frequency.  I have the following ideas:
1)  Double Side band Measurement with a fixed LO.  No RF filter needed.  Use a band pass filter on the LO.   IF needed, break the IF band up so low pass filters  can be use to reject the LO signal.  Issue is I need data for only 700  and 900 MHz but with the IF stepped every 10 MHz (or 10 points).  Therefore I need 40 calibrations and measurements.
2)  Fixed RF.  I can set a bandpass filter on the RF (BW 5% or 35 to 45 MHz) so that a 4 MHz is flat and the signal is down 20 dB at 20 MHz offset (I realized I will not be able to measure 10 MHz).  I could use a low pass filter on the IF and under this condition I only need four calibrations and measurements.  The NFA only has a fixed LO/swept IF or swept LO/fixed IF mode.  Not sure how the NFA would be set up. (I do have a call into the Call Center but I figured I would ask here anyway).
Any comments (pro's, con's) or new ideas would be greatful.
Michael J. Virostko
Principal Product Application Engineer
Integrated Device Technology, Inc.
Westford, MA USA
回帖(1)
李欢
2019-1-22 09:42:31
嗨迈克尔 - 我被告知安捷伦直接回复了你。
希望一切安好 -
以上来自于谷歌翻译
     以下为原文
  Hi Michael -
I am told Agilent has replied to you directly.
Hope all is well -
举报
更多回帖
