你好,
我需要类似的东西,并开始尝试删除模块的头,这是一个有点不起动器。认为这需要热气和一些耐心。最后,我用DRIMEL来切断尽可能多的模块头(确保没有短路),然后焊接到我需要的头引脚上。
不幸的是,这两个模块头不在一个“0.1”间距,所以你不能轻易附加到一块Velo板。您可以形成0.1个“头”轻微,并可以创造性地与这种类型的垂直安装头:
HTTP://UK.FARNELL.COM/GULULL CONTROREST技术/BG301-04-A0540-L B/Booad to Tab-Dead /DPosiD/DP/2458465
这可以让你对插销的偏移足够大,但总是很紧。
什么样的特点会成为一个好的突破板。例如:
1)0.1个“孔”的矩阵
2)CR2032电池座
3)LED
4)最小的尺寸,还是大量的面积增加更多的组件?
当做
齐格斯
以上来自于百度翻译
以下为原文
Hi,
I needed something similar and started by trying to desolder the headers from the module, which was a bit of a non-starter. Think it would require hot-air and some patience. In the end, I used a dremel to cut of as much of the module headers as I could (Ensuring no shorts were left), and then soldered onto the header pins where I needed to.
Unfortunately, the two module headers are not on a 0.1" pitch, so you can't easily attach to a piece of vero-board. You can form 0.1" headers slightly, and can get creative with this type of header mounted vertically:
http://uk.farnell.com/global-connector-technology/bg301-04-a-0540-l-b/board-to-board-header-4-position/dp/2458465
This may allow you to offset the pins by roughly enough, but it's always a tight fit.
What features would make a good breakout board. E.g. :
1) Matrix of 0.1" holes
2) CR2032 battery holder
3) LED's
4) Minimal size, or plenty of area to add more components?
Regards
Zigs
你好,
1)0.1个“孔”的矩阵
2)CR2032电池座
3)LED
当做
齐格斯
以上来自于百度翻译
以下为原文
Hi,
3) LED's
Regards
Zigs
举报
