我不知道你在做什么,这是行不通的。
我一直在MATLAB中这样做。
以下是一些随机的想法:使用Command Expert或Agilent Connection Expert中的交互式I / O功能,一次测试一个命令。
如果他们手动工作,那么问题可能在LabView中。
尝试不同的深度,从低至16个样本开始,甚至更低。
确保您知道插值是打开还是关闭。
如果打开了插值,那么您可能会获得高达16倍的数据,并且您的接收缓冲区可能不够大LabView是否有用户创建的模块库,就像Mathworks一样?
如果是这样,你应该看看那里。
可能是时候与您当地的技术呼叫中心和/或LabView支持联系。
很多人已经成功地做了多年。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
I don't know what you are doing that's not working. I do this all the time in MATLAB.
Here are some random ideas:
Use Command Expert, or the Interactive I/O capability in Agilent Connection Expert, to test out your commands, one at a time. If they work manually, then the problem may be in LabView.
Try different depths, starting as low as 16 samples, or even less. Make sure you know whether interpolation is turned on or off. If interpolation is on, then you may get up to 16 times as much data as you expect, and your receive buffer may not be large enough
Does LabView have a library of user-created modules, like Mathworks does? If so, you should look there.
It may be time to get in touch with your local Technical Call Center and/or LabView support. Many people have done this successfully for years.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
我不知道你在做什么,这是行不通的。
我一直在MATLAB中这样做。
确保您知道插值是打开还是关闭。
如果是这样,你应该看看那里。
很多人已经成功地做了多年。
以上来自于谷歌翻译
以下为原文
Al
举报
