Microchip
直播中
h1654155275.5950
8年用户 206经验值
私信 关注
[问答]
使用sim800中继PIC控制器中的问题
嗨,我的任务是在中继上,每当有来自发送者的消息,中继之后,应该有一个确认消息给发送者,中继***作。没有确认消息,我的中继***作,但是每当我插入一个函数来发送一个消息时,我的代码就会出现故障。继电器操作,也没有消息。我不明白为什么会这样。我只是尝试发送MSG,然后它的OK,但在while循环,它没有显示任何结果,在这里接收消息我已经使用中断服务例程。下面我附上代码请通过它,告诉我哪里错了You酸奶
以上来自于百度翻译
      以下为原文
    hi ,
my task is to On the relay whenever there is message from sender , after relay on there should be acknowledge message to sender that relay is operated.without acknowledge message my relay is operated , but whenever i inserted a function for sending a message my code get malfunctioning ,neither relay operated nor message . i could not understand why this happening. i simply tried for sending msg then its ok but in while loop it is not showing any result,
here to receive message i have used interrupt service routine.below i have attached code please go through it ,
and tell me where i am wrong
thanking you
yogesh
//LCD decleration//
#define TRUE 1
#define bool_val_1 flags. f0
#define LCD_DIR TRISD
#define CTRL_DIR TRISB
#define LCD PORTD
#define RS PORTB.F0
#define E PORTB.F1
#include"lcd.h"
#define STRLEN 55
#define index 2
unsigned char flag=0;
unsigned char flag1=0;
volatile int flag2=0;
unsigned char t,send;
volatile unsigned char rcindex;
volatile unsigned char rcbuf[STRLEN];
unsigned char num[]="918208996450";
unsigned char i,j;
unsigned char rcvd[13];
unsigned char Msg[]="Relay On";
unsigned char num1[12];
unsigned char count;
void UART_Init(void)
TXSTA.TXEN=1; // enable transmitter
TXSTA.BRGH=1; // enable high baud rate
RCSTA.CREN=1; // continuous data receiption
//configure input output
TRISC.TRISC6=1; // rRX pin as a input
TRISC.TRISC7=1; // TX pin as a input
TRISC.TRISC0=1;
SPBRG=103; // set buad rate 9600
PIE1.RCIE=1; //enable USART receive interrupt
RCSTA.SPEN=1; //enable USART
///////////Initialise Message///////////////
void Init_Msg()
UART1_Write_Text("AT+CMGS="+918446323311"r");
delay_ms(500);
UART1_Write_text("Relay Opearted r");
UART1_Write(26);
UART1_Write(0x1A);
void main() {
     INTCON.PEIE=1; //enable interrupt
       INTCON.GIE=1; // enable globle interrupt
     CTRL_DIR=0X00;
     LCD_DIR=0X00;
     init_lcd();
     delay_ms(500);
      //Init_gsm();
      UART_Init();
      delay_ms(500);
      UART1_Write_Text("ATE0rn");
      delay_ms(500);
  //USART_puts("intialisation in complete!n");
// UART1_Write_Text("AT+CPBR=3rn");
  delay_ms(500);
  UART1_Write_Text("AT+CMGF = 1r");
  Delay_ms(1000);
UART1_Write_Text("AT+CNMI=2,2,0,0,0r");
Delay_ms(1000);
  cmd_lcd(0x80);
  string_lcd("Init Complete");
   while(1)
   if(flag)
            // check();
             //cmd_lcd(0x80);
             //string_lcd(rcbuf);
             for(i=8;i<20;i++)
             {rcvd[i-8]=rcbuf;}
                 if(rcvd[0]=='9')
                 if(rcvd[1]=='1')
                  if(rcvd[2]=='8')
                   if(rcvd[3]=='2')
                    if(rcvd[4]=='0')
                     if(rcvd[5]=='8')
                      if(rcvd[6]=='9')
                       if(rcvd[7]=='9')
                        if(rcvd[8]=='6')
                         if(rcvd[9]=='4')
                           PORTB.F6=1;
                 delay_ms(500);
                 PORTB.F6=0;
                 delay_ms(1000);
                 delay_ms(500);
                 cmd_lcd(0x80);
                 string_lcd(rcbuf);
                 delay_ms(1000);
                 UART1_Write_text("Relay Opearted ");
                 UART1_Write(26);
                 UART1_Write(0x1A);
              flag=0;
void interrupt(void)
if(PIR1.RCIF) //check the receive interrupt flag has fired
t=RCREG;
if((t!='n')&&(rcindex {
    rcbuf[rcindex]=t;
     if(rcbuf[0]=='+')
      rcindex++;
     else
      rcindex=0; //reset string index
      flag=0;
else
flag=1;
rcindex=0;}
PIR1.RCIF=0;
回帖(3)
李兆峰
2019-1-17 14:49:57
可能的是,这些结构构件
以上来自于百度翻译
      以下为原文
    Possibly, these structure members
PIR1.RCIF
and more, should bePIR1bits.RCIF
举报
王焕树
2019-1-17 14:56:08
这不是一个完整的程序。配置设置在哪里,包括哪些?在所有其他初始化完成后,不要设置中断使能位。您有一个Voice变量“FLAG2”,这是您永远不会使用的。您使用的是另一个称为“标志”的标志,它应该是易失性的,但不是(任何在中断服务中写入的,并且在服务之外读取的,必须是易失性的)。只要调用一个函数“中断”就不会使它成为中断服务。您必须使用“中断”作为具有不同名称的函数的限定符,例如,这是毫无意义的。这是只读标志。唯一的方法是通过阅读RCREG,你已经完成了。
以上来自于百度翻译
      以下为原文
    That is not a complete program. Where are the config settings and includes?
void main() {
Do not set the interrupt enable bits until AFTER all the other initialisation is complete.
You have a voatile variable "flag2" which you never use. You do use another called "flag", which should be volatile, but is not.
(Anything written inside an interrupt service, and read outside the service, must be volatile.)
Just calling a function "interrupt" does not make it an interrupt service. You must use "interrupt" as a qualifier for a function with a different name, e.g.
void interrupt my_isr(void)
PIR1.RCIF=0;
This is pointless. That is a read-only flag. The ONLY way to clear it is by reading RCREG, which you have already done.
举报
赵敏
2019-1-17 15:08:37
对不起,先生,我提到我正在使用Mikro C Pro为PIC。I Mikro C Pro用于设置RCIF标志ISPIR1.RCIF=1的结构;
以上来自于百度翻译
      以下为原文
sorry sir i dint mention that i am using Mikroc Pro for PIC.
i mikro c pro the structure for setting RCIF flag is
PIR1.RCIF=1;
举报
更多回帖
