Microchip
直播中
杜云
7年用户 307经验值
私信 关注
[问答]
C版本中的简单PIC12F509代码但不起作用
你好,请问你知道为什么我的PIC12F509的C代码(XC8)不工作吗?它所要做的是读取GP5上的方波电压输入,然后将GP4从高变为低,反之亦然,每秒GP5低。然而,GP4总是保持低位。你知道为什么吗?它建立成功但不工作
以上来自于百度翻译
      以下为原文
    Hello,
Please do you know why my C code (XC8) for PIC12F509 doesnt work?
All its supposed to do is read a square wave voltage input on GP5, and then change GP4 from high to low and vice versa, every second low-going of GP5.
However, GP4 is always just staying low. Do you kow why?
It builds successfully but doesn’t work
* File: jitter.c
* Author:
* Created on 8 sept 2017, 23:55
//this code jitters
//This uses PIC12F509
//MPLAB X IDE
//XC8 C compiler (free)
#define _XTAL_FREQ 4000000
#include
#include
#pragma config OSC = IntRC // Oscillator Selection bits (external RC oscillator)
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF // Code Protection bit (Code protection off)
#pragma config MCLRE = OFF // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is MCLR)
//I have not set the MCLR pin as an input because it will be noise susceptible.
//Therefore i set MCLR up as reset, but i will never use it as reset..but will
//simply tie the pin top Vdd on the PCB.
//Declare functions which set up the microcontroller
//void disable_interrupts(void); //How do this?
//void disable_pullups(void); //How do this?
// TRIS = 0x18;
//Declare variables
    uint8_t count;
void main(void) {
    GP0 = 0;
    GP1 = 0;
    GP2 = 0;
    GP4 = 0;
    GP5 = 0;
    OPTION = 0xD7;
    TRISGPIO = 0x20;
    GP4 = 0;
    //5 second delay
    for (count=1;count<=50;count++) {
    __delay_ms(100);
    while(GP5 == 0) ;
    while(GP5 == 1) ;
    //STATUS LOW FIRST
    //When it gets to this point, the STATUS input has just gone low
    __delay_us(500);
    GP4 = 0; //FET OFF
    while(1){
    while(GP5 == 0) ; //See out the rest of low STATUS
    while(GP5 == 1) ; //See out the high STATUS
    while(GP5 == 0) ; //See out the low STATUS
    //STATUS LOW SECOND
    __delay_us(500);
    GP4 = 1; //FET ON
    __delay_us(500);
    GP4 = 0;
    while(1){;}
    return;
回帖(2)
王焕树
2019-1-16 12:10:10
不要试图同时解决两个问题,你能简单地让GP4在没有GP5测试的情况下闪现吗?
以上来自于百度翻译
      以下为原文
    Don't try to solve two problems at once.
Can you simply get GP4 to flash without the GP5 tests?
举报
李涛
2019-1-16 12:15:28
选项=0xD7;假设哪些位被设置而不是一些随机数。
以上来自于百度翻译
      以下为原文
    OPTION = 0xD7;
Say what bits are set rather than some random number.
举报
更多回帖
