嗨 - 如果DRO /第二个LO失败,那么第一个对齐失败将是第二个LO功率电平。
错误队列显示顶部的最后一个错误,因此您必须单击“下一页”并向下看底部。
从发送的屏幕截图中,我没有看到错误,“-340,校准失败,ALIGN_2ND_LO_PWR”。
所以,我认为DRO / 2nd LO不是问题所在。
第二LO功率对准不使用主RF路径。
相反,它由低频带组件感测,并由低频带组件上的可变增益放大器补偿。
希望这可以帮助 -
以上来自于谷歌翻译
以下为原文
Hi -
If the DRO / 2nd LO failed, then the very first alignment failure will be for the 2nd LO power level. The error queue shows the last error at the top, so you have to click on the Next page and look down at the bottom. From the screen shots sent, I didn’t see the error, “-340, Calibration Failed, ALIGN_2ND_LO_PWR”. So, I don’t think that the DRO / 2nd LO is the problem. The 2nd LO power alignment doesn’t use the main RF path. Instead it is sensed by the low band assembly and is compensated for by the variable gain amplifier on the low band assembly.
Hope this helps -
第二LO功率对准不使用主RF路径。
希望这可以帮助 -
以上来自于谷歌翻译
以下为原文
Hi -
Hope this helps -
举报
