祝大家好,谢谢你的回复。
那么,伺服i的最大运行电流应该在4.8V时为180mA。
我不确定浪涌电流,但我在运行时用pps做的读数是一致的。
这是电流表型号:ksc1303-2,我认为它是基于我读过的数据表的直流电流表。
所以我的程序就像:伺服机构每秒钟都会发出一个角度运动的命令。
我在整个过程中监视当前读数(空闲和运行),因此命令每隔20毫秒就连续一次(这是我假设我的程序可以从pps读取电流的最低时间,因为当它低于20毫秒时,
发生查询错误。我确实需要读数之间的间隙非常小,以图形方式表示伺服运行状态下的当前读数,只需要大约100毫秒即可达到一定的角度。)。
我的空闲电流读数很好,但运行,我不确定。
而且,我设法使用34401A数字万用表测量电流并增加了我的困惑,数字万用表直流读数与pps相同,而数字万用表交流读数与模拟直流电流表相同。我不明白
它!
:/谢谢你的时间。
以上来自于谷歌翻译
以下为原文
Good Day Sir,
Thanks for the reply. Well, the maximum running current of the servo i have should be at 180mA at 4.8V. I am not sure about the surge current but the readings i made with the pps at running were consistent. This is the ammeter model number : ksc1303-2, i think it's a dc ammeter based on the datasheet i read about it.
So my program goes like: a servo is given a command to make angle movements each second. I monitor the current readings (idle and running) through the whole duration of the process so the command is in a row for every 20msec (that's the lowest time i assumed my program can read current from the pps since when it's lower that 20msec, a query error occurs. And i really need a very small gap between readings to graphically represent the current reading at running state of the servo which only takes about 100msec to reach a certain angle.). My Idle current readings are good but the running, i am not sure. And also, i managed to use a 34401A DMM to measure the current and adding to my confusion, the DMM dc readings is the same with the pps and the DMM ac readings were the same with the analog dc ammeter.. I don't get it! :/
Thank you for the time. :)
祝大家好,谢谢你的回复。
它!
:/谢谢你的时间。
以上来自于谷歌翻译
以下为原文
Good Day Sir,
举报
