亲爱的米雷克;
谢谢你的依赖。
我以为我在解决这个问题上运气不好。
要回答这个问题:您是否有任何机会使用Agilent / HP电源(E3631A或E3632A)并将其放在8753的左上方?
答:我发送8753C进行维修,我不知道技术人员做了什么。
我读过如果错误地更换电源,可能会损坏设备。
我觉得这很容易做到。
我权衡了将设备送去维修或自行完成的好处和后果,我决定将设备送去维修。
如果您知道电源安装的详细信息,在进行错误操作和进一步损坏设备方面,我很乐意阅读它。
当你写道:“回到白天” - 我意识到你必须是一个长时间使用网络分析仪的人,8753C是一个旧单位,但它是一个很好的单位。
与8753D及其后的所有其他网络分析仪相比,它具有许多优势。
例如,单独的S参数测试集具有其优点和缺点。
当你写道时,我不太明白你写的是什么:“等几天,它通常会消失”你能解释一下测试是如何进行的吗?
感谢您的回复。
以上来自于谷歌翻译
以下为原文
Dear Mirek;
Thank you for your rely. I thought I was out of luck with regard to solving this problem.
To answer this question:
Did you by any chance use one of the Agilent/HP power supply (E3631A or E3632A) and place that on the top left side of the 8753?
Answer: I sent the 8753C in for repair and I don't have any idea what the techs did.
I read that if one replaces the power supply incorrectly, it is possible to damage the unit. I got the impression that this was easy to do. I weighed the benefits and consequences of sending the unit in for repair or doing it by myself and I decided to send the unit in for repair. If you know the details of the power supply installation, in terms of doing it incorrectly and damaging the unit further, I would be happy to read about it.
When you wrote:
"Back in the day" - I realized that you must be a guy working with network analyzers for a long time, the 8753C is an old unit but it is an excellent unit. It has a lot of advantages over the 8753D and all the other network analyzers that followed it. For example, a separate S parameter test set has its advantages and disadvantages.
I didn't quite understand what you wrote when you wrote:
"Waite couple of days and it usually go away"
Can you explain how the test was conducted?
Thanks for your reply.
亲爱的米雷克;
谢谢你的依赖。
我以为我在解决这个问题上运气不好。
我觉得这很容易做到。
感谢您的回复。
以上来自于谷歌翻译
以下为原文
Dear Mirek;
举报
