嗨Minas,Spectrasys用于轻松制定您的频率计划,并允许您评估合适的过滤器,以删除不需要的混合产品。
它可用于显示频谱分析仪上的频谱。
它还可以显示感兴趣频率的级联增益,NF P1dB等。
请记住,过滤器型号是理想的,您可能最终会得到一个不可能的过滤器,以实现您需要移除的麻烦刺。
要查看模拟的时域响应,您需要瞬态许可证。
如果你有这个已经看过附加的SIM文件。
这显示了2.8GHz的源驱动50欧姆负载。
我已经包含了瞬态数据的FFT函数,以检查您在tine域中看到的内容是否与您在频域中的预期相匹配。
这可以在方程式中找到。
欢呼DanEdited:dan.peabody于2014年3月17日上午4:09
以上来自于谷歌翻译
以下为原文
Hi Minas,
Spectrasys is used to easily develop your frequency plan and allow you to evaluate a suitable filter to remove unwanted mixing products. It can be used to show the spectrum as you would see on your spectrum analyser. it can also show the cascaded gain, NF P1dB etc for the frequency of interest.
Bear in mind that the filter models are ideal and you may end up with an impossible filter to realise if you have a troublesome spur you need to remove.
To see the time domain response of your simulation you will need the transient licence.
If you have this already have a look at the attached sim file. This shows a 2.8GHz source driving a 50 ohm load.
I have included an FFT function of the transient data to check what you are seeing in the tine domain match what you expect in the frequency domain. This is found in the Equations.
cheers
Dan
Edited by: dan.peabody on Mar 17, 2014 4:09 AM
附件
它可用于显示频谱分析仪上的频谱。
如果你有这个已经看过附加的SIM文件。
这可以在方程式中找到。
以上来自于谷歌翻译
以下为原文
Hi Minas,
cheers
Dan
附件
举报
