是德科技
直播中
张倩
7年用户 224经验值
私信 关注
[问答]
E5071C未校正的系统性能
嗨我正在尝试在执行E5071C的2端口校准后提取未校正系统性能的数据。
我在网上看到,这可以在执行校准后提取但是我无法做到。
有了B系列,有一个VBA程序可以做到这一点,但该程序不适用于'C'模型。
有人可以对此有所了解吗?
谢谢
以上来自于谷歌翻译
     以下为原文
  Hi
I am trying to extract the data for the uncorrected sytem performance after performing a 2-port calibration of the E5071C.
I've read online that this is possible to extract after performing the calibration however I have been unable to do it. With the B-series there is a VBA program available to do this but that program does not work for the 'C' model.
Can anyone shed some light on this please?
Thanks
回帖(5)
周烜
2019-1-9 16:12:51
通常,VBA源代码位于Excel文件中。
如果这是由某人编写和保护,那么你将无法达到它。
VBA是“Visual Basic for Applications”并且始终存在于文件中。
这是一个Excel文件吗?
以上来自于谷歌翻译
     以下为原文
  Usually the VBA source code is inside of an Excel file.  If this was written and protected by someone then you won't be able to get to it.  VBA is "Visual Basic for Applications" and always exists inside the file.  Is this an Excel file?
举报
张倩
2019-1-9 16:23:56
我试图在excel中打开,它不会打开。
它仅作为VBA文件列出。
我附上了以下文件谢谢
以上来自于谷歌翻译
     以下为原文
  I have tried to open in excel, it wont open. Its listed simply as a VBA file.
I've attached the file below
Thanks
附件
举报
周烜
2019-1-9 16:38:21
我在记事本中打开它,它看起来像VB 6.0表单文件,但它有二进制值。
我不认为VB 6.0文件中有任何bianry。
我以前记得在记事本中打开它们,它们都是ASCII字符。
如果这很简单,我可以提供帮助。
以上来自于谷歌翻译
     以下为原文
  I opened this up in Notepad and it looks like a VB 6.0 form file but there are binary values in it.  I don't think VB 6.0 files had any bianry in them.  I used to remember opening them up in Notepad and they were all ASCII characters.  If it's something simple I might be able to help.
举报
张倩
2019-1-9 16:54:49
在视觉基础方面,我再次成为新手;
该程序似乎具有我需要的所有测量,但是当我尝试在设备上运行宏时,它会给出一个错误消息,它被设计为在B系列上运行。感谢您的帮助!
以上来自于谷歌翻译
     以下为原文
  Again im a novice when it comes to visual basic; The program seems to have all the measurements I need however when I try to run the macro on the unit it gives an error message that it was designed to run on a series B.
Thanks for your help!
举报
更多回帖
