4.al版本的Datalink的calkit编辑器存在缺陷。
calkit中定义的标准必须具有单调递增的标准数字。
FieldFox的固件具有相同的缺陷,因此在读取calkit文件时具有相同的要求。
独立的calkit编辑器用于强制执行此标准编号,但已删除此编辑器以支持PNA的一些旧的必需行为。
因此,新编辑器(1.0.5018.0)不会强制执行此操作,并且可以创建(当前)与DataLink calkit编辑器和FieldFox固件不兼容的工具包。
要使您的工具包与当前的DataLink calkit编辑器和FieldFox固件兼容,您可以手动调整标准数字(使用文本编辑器)为单调递增的整数,从1开始。我已附加您的工具包,编辑以符合此要求
标准号7和8分别成为标准号5和6。
如果您进行自己的编辑,请确保为您更改标准编号的任何标准调整套件类分配。
未来的FieldFox版本(包括DataLink)将正确使用具有任意标准数字的calkits,如1.0.5018.0 calkit编辑器即可。
抱歉给你带来不便。
会
以上来自于谷歌翻译
以下为原文
There exists a defect in the 4.64 version of Datalink's calkit editor. Defined standards in a calkit must have monotonically increasing standard numbers. FieldFox's firmware has the same defect, so has the same requirement when reading calkit files.
The stand-alone calkit editor used to enforce this standard numbering, but this was removed to support some older required behaviors with PNA. So the new editor (1.0.5018.0) does not enforce this and it is possible to create kits that are (currently) not compatible with the DataLink calkit editor and also FieldFox firmware.
To make your kit compatible with the current DataLink calkit editor and FieldFox firmware, you can manually adjust your standard numbers (with a text editor) to be monotonically ascending integers, starting at 1. I have attached your kit, edited to conform to this requirement. Standard numbers 7 and 8 became standard numbers 5 and 6, respectively. If you do your own editing, make sure you adjust the kit class assignments for any standards whose standard numbers you change.
Future FieldFox releases (including DataLink) will properly consume calkits with arbitrary standard numbers, like the 1.0.5018.0 calkit editor can.
Sorry for the inconvenience.
Wil
附件
标准号7和8分别成为标准号5和6。
抱歉给你带来不便。
会
以上来自于谷歌翻译
以下为原文
Wil
附件
举报
