CRC校验模块计算产生发送数据需要的 CRC 校验序列。计算产生的 CRC 校验需要添加到数据帧上。这个模块同时被接收数据模块用来计算 CRC 校验序列,然后和接收到的 CRC 校验序列进行比较,从而判断传输过程中是否发生错误。CRC 校验模块的主要代码如下:
- include "timescale.v"
- module eth_crc (Clk, Reset, Data, Enable, Initialize, Crc, CrcError);
- parameter Tp = 1;
- //输入、输出信号
- input Clk;
- input Reset;
- input [3:0] Data;
- input Enable;
- input Initialize;
- output [31:0] Crc;
- output CrcError;
- reg [31:0] Crc;
- wire [31:0] CrcNext;
- //计算获得 CRC 序列
- assign CrcNext[0] = Enable & (Data[0] ^ Crc[28]);
- assign CrcNext[1] = Enable & (Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29]);
- assign CrcNext[2] = Enable & (Data[2] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[30]);
- assign CrcNext[3] = Enable & (Data[3] ^ Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30] ^ Crc[31]);
- assign CrcNext[4] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[0];
- assign CrcNext[5] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[1];
- assign CrcNext[6] = (Enable & (Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30])) ^ Crc[ 2];
- assign CrcNext[7] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[3];
- assign CrcNext[8] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[4];
- assign CrcNext[9] = (Enable & (Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30])) ^ Crc[5];
- assign CrcNext[10] = (Enable & (Data[3] ^ Data[2] ^ Data[0] ^ Crc[28] ^ Crc[30] ^ Crc[31]))^ Crc[6];
- assign CrcNext[11] = (Enable & (Data[3] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[31]))^ Crc[7];
- assign CrcNext[12] = (Enable & (Data[2] ^ Data[1] ^ Data[0] ^ Crc[28] ^ Crc[29] ^ Crc[30]))^ Crc[8];
- assign CrcNext[13] = (Enable & (Data[3] ^ Data[2] ^ Data[1] ^ Crc[29] ^ Crc[30] ^ Crc[31]))^ Crc[9];
- assign CrcNext[14] = (Enable & (Data[3] ^ Data[2] ^ Crc[30] ^ Crc[31])) ^ Crc[10];
- assign CrcNext[15] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[11];
- assign CrcNext[16] = (Enable & (Data[0] ^ Crc[28])) ^ Crc[12];
- assign CrcNext[17] = (Enable & (Data[1] ^ Crc[29])) ^ Crc[13];
- assign CrcNext[18] = (Enable & (Data[2] ^ Crc[30])) ^ Crc[14];
- assign CrcNext[19] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[15];
- assign CrcNext[20] = Crc[16];
- assign CrcNext[21] = Crc[17];
- assign CrcNext[22] = (Enable & (Data[0] ^ Crc[28])) ^ Crc[18];
- assign CrcNext[23] = (Enable & (Data[1] ^ Data[0] ^ Crc[29] ^ Crc[28])) ^ Crc[19];
- assign CrcNext[24] = (Enable & (Data[2] ^ Data[1] ^ Crc[30] ^ Crc[29])) ^ Crc[20];
- assign CrcNext[25] = (Enable & (Data[3] ^ Data[2] ^ Crc[31] ^ Crc[30])) ^ Crc[21];
- assign CrcNext[26] = (Enable & (Data[3] ^ Data[0] ^ Crc[31] ^ Crc[28])) ^ Crc[22];
- assign CrcNext[27] = (Enable & (Data[1] ^ Crc[29])) ^ Crc[23];
- assign CrcNext[28] = (Enable & (Data[2] ^ Crc[30])) ^ Crc[24];
- assign CrcNext[29] = (Enable & (Data[3] ^ Crc[31])) ^ Crc[25];
- assign CrcNext[30] = Crc[26];
- assign CrcNext[31] = Crc[27];
- //初始化和复位 CRC 校验序列
- always @ (posedge Clk or posedge Reset)
- begin
- if (Reset)
- Crc <= #1 32'hffffffff;
- else
- if(Initialize)
- Crc <= #Tp 32'hffffffff;
- else
- Crc <= #Tp CrcNext;
- end
- //发生错误时的结果
- assign CrcError = Crc[31:0] != 32'hc704dd7b; // CRC not equal to magic number
- endmodule
