您应该能够使用短BNC电缆,没有任何问题。
我在工厂支持中谈到了这一点,这里是信息的要点:如果你想这样做,没问题,只要认识到如果你在一个通道上使用电缆进行歪斜校准,而在另一个通道上进行歪斜校正
电缆,2个通道不会排队。
顺便说一下,我从未进行过“官方”偏斜校准。
我主要使用串行总线,触发器的位置无关紧要。
所有测量都在通道之间进行。
我通过将它们放在相同的信号上来调整相对于彼此的通道,并在通道对话框中调整偏斜。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
You should be able to use a short BNC cable with no problems. I spoke to factory support about this and here's the gist of the message:
If you want to do this, no problem, just recognize that if you do a skew cal on one channel with the cable, and a skew cal on another channel with out the cable, the 2 channels won't line up.
BTW, I never do an 'official' skew calibration. I'm mostly working on serial buses, and the location of the trigger doesn't matter. All measurements are made between channels. I deskew the channels relative to each other by putting them both on the same signal, and adjusting the skew in the Channel dialog.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
电缆,2个通道不会排队。
所有测量都在通道之间进行。
以上来自于谷歌翻译
以下为原文
Al
举报
