你好@ chuck_s,
请注意,ZCU102生产芯片评估套件中的许可证凭证仅限于诺德锁定和放大器。
设备锁定到XCZU9EG(而不是XCZU9EG-ES1或XCZU9EG-ES2)。
因此,为了在您的设计中定位XCZU9EG-ES1 snd /或XCZU9EG-ES2,您需要一个单独的Early Access许可证,一旦您获得对Zynq UltraScale + MPSoC-EA Lounge的访问权限,就可以获得该许可证:http:// www
.xilinx.com / member / zynq_ultrascale_errata.html,以便您可以获得必要的ES许可证。
你有权访问这个吗?
如果没有,只有在授予对Zynq UltraScale + MPSoC - EA Lounge的访问权限后,才会将ES许可证添加到您的许可帐户。
您能否点击此链接,看看您是否看到“欢迎新用户!”。
如果是,请按照步骤请求访问。
完成并获得批准后,所需的许可证将添加到您的许可帐户中。
登录休息室后,将有关于如何获得ES许可证的说明(称为“Zynq UltraScale + MPSoC ES 2017.1设备”)。
一旦您拥有此Zynq UltraScale + MPSoC ES 2017.1设备以及您的节点锁定&
设备锁定到XCZU9EG许可证后,您就可以使用ES1,ES2和XCZU9EG的生产部件来实现。
希望以上是清楚的。
亲切的问候,
Anatoli Curran,
Xilinx技术支持
亲切的问候,Anatoli Curran,Xilinx技术支持-----------------------------------------
--------------------------------不要忘记回复,工作,并接受解决方案.----
以上来自于谷歌翻译
以下为原文
Hello @chuck_s,
Please note that the license voucher in the ZCU102 production silicon evaluation kit only comes with a Node locked & Device-locked to the XCZU9EG (and not XCZU9EG-ES1 or XCZU9EG-ES2).
Therefore, for targeting XCZU9EG-ES1 snd/or XCZU9EG-ES2 in your design, you'd need a separate Early Access license that can be given to you once you have gained access to the Zynq UltraScale+MPSoC – EA Lounge: http://www.xilinx.com/member/zynq_ultrascale_errata.html, so that you can obtain the necessary ES licenses.
Do you have access to this already? If not, the ES licenses will only be added to your Licensing account once the access to Zynq UltraScale+MPSoC – EA Lounge is granted.
Can you please click on this link and see if you see “Welcome new user!”. If so, then please follow the steps to request access. Once done and approved, the required licenses will then be added to your Licensing account.
Once you have logged in into the lounge, there would be instruction on how to obtain an ES license (called “Zynq UltraScale+ MPSoC ES 2017.1 Devices”).
Once you have this Zynq UltraScale+ MPSoC ES 2017.1 Devices together with your Node locked & Device-locked to the XCZU9EG license, you will then be able to implement with ES1, ES2 and the production parts of XCZU9EG.
Hope the above is clear.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Kind Regards,
Anatoli Curran,
Don’t forget to reply, kudo, and accept as solution.
你好@ chuck_s,
你有权访问这个吗?
如果是,请按照步骤请求访问。
希望以上是清楚的。
亲切的问候,
Anatoli Curran,
Xilinx技术支持
以上来自于谷歌翻译
以下为原文
Hello @chuck_s,
Kind Regards,
Anatoli Curran,
Kind Regards,
Anatoli Curran,
举报
