你好@ fandrei,
看起来该工具无法检测到您的SDSoC 60天评估许可证。
您能否分享一份XINFO报告的副本(在您看到此许可错误的机器上生成)进行检查?可以通过在Vivado TCL控制台中运行“report_environment -file xinfo.txt”命令来生成Xinfo.txt
如果您有任何疑问,请告诉我。
亲切的问候,Anatoli Curran,Xilinx技术支持-----------------------------------------
--------------------------------不要忘记回复,工作,并接受解决方案.----
以上来自于谷歌翻译
以下为原文
Hello @fandrei,
Looks like the tool can't detect your SDSoC 60-day Evaluation license.
Can you please share a copy of your XINFO report (generated on the machine where you are seeing this licensing error), for examination?
Xinfo.txt can be generated by running the "report_environment –file xinfo.txt" command in Vivado TCL console.
If you have any questions, please let me know.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Don’t forget to reply, kudo, and accept as solution.
你好@ fandrei,
如果您有任何疑问,请告诉我。
以上来自于谷歌翻译
以下为原文
Hello @fandrei,
Kind Regards,
Anatoli Curran,
举报
