是德科技
直播中
董超
7年用户 266经验值
私信 关注
[问答]
HP8563E A15射频板上的100MHz VCO故障
亲爱的,我在HP 8563E频谱分析仪上遇到了问题。
A15射频板上的100MHz VCO不会振荡(在VCO的输出端进行测量,带有TEST位置的带子)。
我确信VCO有故障,PLL环路必须工作。
电源轨(+/- 15V)很好。
我检查了有源元件(没有去焊),但没有一个看起来有问题。
调整C750电容器不会带来任何影响。
我很高兴知道是否有人已经经历过(并解决了)这样的故障,或者VCO的某个部件是否容易出现故障......我的备件中几乎所有的VCO有源元件(100MHz xtal除外),但是
在射频板上脱焊之前,我很乐意接受你的建议。
感谢您的阅读和帮助。
干杯,多米尼克B.
以上来自于谷歌翻译
     以下为原文
  Dear all,
I have an issue on a HP 8563E Spectrum Analyzer. The 100MHz VCO on the A15 rf Board doesn't oscillate (measurement made at output of the VCO with strap on TEST position). I am sure the VCO is faulty, the PLL loop must work.
Power rails (+/- 15V) are fine.
I have checked the active components (without de-soldering) and none of them seem faulty.
Adjustment of C750 capacitor doesn't bring anything.
I would be happy to know if somebody has already experienced (and solved) such failure or if  a component of the VCO is prone to fail ...
I have almost all the VCO active components in spare parts (except the 100MHz xtal) , but before de-soldering on the rf Board, I would be very happy to have your advice.
Thanks for reading and for your help.
Cheers,
DominiqueB
回帖(1)
董超
2018-12-28 16:24:01
发现失败了。
馈电Q701和U700的晶体管Q700(PTX222A)有故障。
安装新的振荡器后,振荡器工作正常。
所以问题解决了。
希望这些信息可以帮助其他人有类似的问题。
干杯,多米尼克B.
以上来自于谷歌翻译
     以下为原文
  Found the failure. The transistor Q700 (PTX222A) feeding Q701 and U700 was defective. After mounting a new one, oscillator works fine.
So problem solved.
Hope this information can help somebody else having similar problem.
Cheers,
DominiqueB
举报
更多回帖
