Microchip
直播中
韩婧
8年用户 173经验值
私信 关注
[问答]
Sizeof不适用于类型,只适用于变量?
嗨,Sizeof不使用类型,只使用变量。我希望下面的代码工作,但它不起作用。为了工作,我必须做以下的调整(我觉得很可怕):谁能给我一个提示,或者告诉我如何做类型的工作。谢谢。
以上来自于百度翻译
      以下为原文
Hi,
Sizeof does not work with types, only with variables.
I expected the code below to work, but it does not work.
#define NAME_TASK_SIZE (16)
typedef struct {
        unsigned char name[NAME_TASK_SIZE];
        float descida;
        float descanso;
        float subida;
}t_tupla;
void DATABASE_Delete(unsigned char index)
    unsigned char i;
    for(i=0;i<(sizeof t_tupla);i++)
        EEPROM_Write_Byte(((sizeof t_tupla)*index)+3+i,0xFF);
To work I had to make the following adaptation (which I found horrible):
    unsigned char i;
    t_tupla var;
    for(i=0;i<(sizeof var);i++)
        EEPROM_Write_Byte(((sizeof var)*index)+3+i,0xFF);
Can anyone give me a hint or tell how to do sizeof work with types.
Thank you.
回帖(1)
殷谷光
2018-12-27 16:26:12
嗨,现在开始工作了。谢谢你:
以上来自于百度翻译
      以下为原文
    Hi,
It's working now. Thank you
grin:
举报
更多回帖
