工程资源中心
直播中
尹丽
8年用户 200经验值
私信 关注
[电源设计]
双路USB C型DFP完整集成解决方案
            PMP40270 is a dual USB type-C DFPs reference design, as a cigar lighter adapter. It has a high effieicny DCDC converter LMS3635  inside, combined with a low cost USB type-C source controller TPS25821 for each port. Full voltage range of a 12V car battery, as well as the transistion voltage up  (...)
主要特色
  • Full integration solution for USB Type-C DFP port
  • IEC ESD protection on CC1/CC2
  • USB BC1.2 DCP charging protocols supported
  • High efficiency up to 95% with full load
  • Compact form factor for CLAs
更多回帖
