工程资源中心
直播中
刘悌耀
9年用户 1153经验值
私信 关注
[电源设计]
为D类音频放大器供电的连续PSU参考设计
            This power reference design generates all voltages to supply a class-D audio amplifier. The main output voltage is 30V and delivers 200W continuously and 750W peak. The first stage is a power-factor corrected Boost. A Flyback converter supplies 12V on primary side as well as 12V@300mA and 3.3V@200mA  (...)
主要特色
  • Low cost PFC + 2-switch forward topology provides 200W average, 750W peak power
  • Constant switching frequency: particularly suitable for audio applications
  • Good plug-to-plug efficiency:  85% @ 115Vac, 87% @ 230Vac
  • Compact construction:  88mm x 173mm, height 35mm
更多回帖
