工程资源中心
直播中
沈铿僖
7年用户 180经验值
私信 关注
[电源设计]
具有输入电压检测功能的高效率三路输出偏置电源设计
            This reference design is a compact and thermally efficient design intended to be used as a bias supply for half-bridge converters. A DCM Flyback with UCC3813-4 controller is used to generate two isolated 12V supplies for half-bridge converter primary driving circuitry. One 5V is generated at the  (...)
主要特色
  • 200VDC to 400VDC input, two isolated 12V output at primary side and one 5V output at secondary side
  • Less than 30 degree C temperature rise on all parts
  • Input voltage sensing circuit included
  • 1" x 1.5" x 0.5" board dimension
  • Test report available
更多回帖
