@rimcrazyph
1)正确安装HLS Webpack和SDSoC开发环境的许可版本的步骤是什么?
您可以从此处安装SDSoC:sdx-development-environments
(运行Web安装程序是个更好的主意)
您可以从此处安装Vivado HLX:vivado-design-tools
在安装Vivado时,如果您希望安装Vivado WebPACK或System Edition或Vivado System Edition,它将允许您选择。
在那里选择WebPACK。
2)由于我已经通过安装SDSoC套件在我的桌面上安装并许可了我的2个SDSoC许可证中的一个,如果正确的程序与我的做法不同,是否有一些特殊的东西,例如在我做之前需要返回我的许可证
在我的桌面上卸载我的开发工具包?
我曾经使用其他软件,这些软件的许可方式是您需要在卸载之前返还许可证,或者您破坏或搞砸了您的许可系统。
不再需要这个过程。
是的,您可以将许可证重新托管给其他主机,如下所述:36136
谢谢,Nupur -----------------------------------------------
--------------------------------------------- Google在发布之前提问
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@rimcrazyph
1) What is the procedure to properly install the HLS Webpack and a licensed version of SDSoC development environment?
You can install SDSoC from here: sdx-development-environments
(Running the web-installer is a better idea)
You can install Vivado HLX from here: vivado-design-tools
While installing Vivado, it will let you select if you wish to install Vivado WebPACK or System Edition or Vivado System Edition. Select WebPACK there.
2) Since I've installed and licensed 1 of my 2 SDSoC licenses on my desktop by just installing the SDSoC kit, if the proper procedure is different from what I did, is there something special like returning my license that is required before I do an uninstall of my development kit on my desktop? I've worked with other software in the past that was licensed in such a manner that you needed to return licenses before uninstalling or you broke or messed up your licensing system.
That process is no longer needed. Yes, you can rehost the license to a different host as mentioned here: 36136
Thanks,
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post
@rimcrazyph
(运行Web安装程序是个更好的主意)
在那里选择WebPACK。
在我的桌面上卸载我的开发工具包?
不再需要这个过程。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@rimcrazyph
Thanks,
Nupur
举报
