工程资源中心
直播中
周睫蒙
8年用户 191经验值
私信 关注
[电源设计]
高效率低成本6.5V 2.5A SEPIC转换器设计
            This 6.5V @ 2.5A SEPIC converter is designed to operate over a very wide input voltage range. After initial power up at 6V input, the converter can operate down to 4.5V input by implementing a voltage doubler for to provide bias power. It requires minimal component count, a small PCB area and offers  (...)
主要特色
  • High efficiency (88% with 2.5A load at 12Vin)
  • Low cost controller
  • Less than 40mm x 47mm area
  • Wide 4.5V - 60V input voltage range
更多回帖
