PMP20322 is a 4-switch buck-boost controller utilizing the LM5175 for consumer applications. This design has a minimum operating input voltage of 10V and a maximum input voltage of 14V. The design is capable of sourcing 2A continuous current at 12Vout. Switching frequency is set to 300kHz. PMP20322 (...)
主要特色
10V to 14V in, output 12V@ 2A
Achieving efficiency of 98% at 12Vin
Compact size, slim form factor, suitable for USB type C dongle
Solution Size: 22mm x 19.5mm
0.1% output ripple without second stage output filter
