工程资源中心
直播中
陈光琦
8年用户 1053经验值
私信 关注
16位高性能隔离数据采集(DAQ)解决方案
            The circuit represents a high-performance data acquisition (DAQ) solution suitable for processing input signals (up to ±12 V) superimposed on large common-mode offsets (tested up to 155 Vp-p from dc to approximately 15 kHz) relative to the ground potential of the system's main power supply  (...)
主要特色
  • Provides 16-bit, 1-MSPS, 120-dB CMRR, 108-dB THD, performance via Isolation
  • Isolated data acquisition to allow for high-voltage common-mode rejection
  • Isolated power supply design
  • Design facilitates injecting high common-mode voltages for testing
更多回帖
