赛灵思
直播中
钱铖
8年用户 196经验值
私信 关注
[问答]
下载文件时出错
多次尝试安装Vivado webpack。
还尝试将驱动器从C:改为D:
安装的最后一步是“下载文件时出错”。
并提示是/否。
两个都试过不行。
请调试附加的日志文件。
此外,我重新格式化了我现有的笔记本电脑并完成了新的win os安装
但是,同样的问题
xinstall_1458790849837.log 22 KB
以上来自于谷歌翻译
以下为原文
Tried several times to install Vivado webpack.
also tried changing drive from C: to D:
While last step in installation it says "Error downloading files". and prompt for yes/no. both tried not working.
Please debug attached log file.
Also, i reformatted my existing laptop and done fresh win os installation
But, the same issue
            xinstall_1458790849837.log ‏22 KB
回帖(8)
王文霞
2018-12-24 13:58:22
嗨,您使用的是网络安装客户端吗?您可以尝试下载Vivado Design Suit单文件下载吗?-Shreyas
--------------------------------------------尝试搜索你的答案
在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号)
并回复.----------------------------------------------
以上来自于谷歌翻译
以下为原文
Hi,
Are you using web install client?
Can you try downloading Vivado Design Suit Single file download?
-Shreyas----------------------------------------------------------------------------------------------
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
举报
陈衡毅
2018-12-24 14:09:01
您好@dhruvkumaarpatel
你尝试过新的下载吗?
提出下载请求@ http://www.xilinx.com/support/service-portal.html
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi @dhruvkumaarpatel
Did you try with a fresh download?
Raise a downaload request @ http://www.xilinx.com/support/service-portal.html
Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
李亮
2018-12-24 14:26:00
@vijayak。
我执行了新的下载请求。它说它不是公司地址,因为我来自大学。但是,我的请求已被接受
以上来自于谷歌翻译
以下为原文
@vijayak. I performed fresh download request.
It says its not corporate address as i am from university.
However,my request has been accepted
举报
陈衡毅
2018-12-24 14:33:07
您好@dhruvkumaarpatel
你的SR号码是多少?
你有没有从支持团队那里听到回复?
以上来自于谷歌翻译
以下为原文
What is your SR number? Did you hearback from the support team?
Thanks,Vijay
举报
更多回帖
