赛灵思
直播中
潘斯凯
7年用户 153经验值
私信 关注
[问答]
Spartan 3E入门套件启动时没有许可证
嗨,大家好,
我确实打开了一个网络案例,但Xilinx拒绝了它,因为他们说我的公司名称无效,现在不会让我创建一个新的网络案例。
Qualitysupport!
也许这里有人可以帮助我:
我在这里有一个Spartan 3E入门套件并且已经下载了Webpack ISE 14.7.XPS抱怨在启动时没有许可证并且hen试图生成比特流失败:错误:EDK  - 信息:安全:71  - 如果部分'xc3s500e的许可证
'可用,它可以使用'XPS_TDP'代替'XPS'.INFO:安全性:61  -  XILINXD_LICENSE_FILE环境变量不是set.INFO:Security:63  -  LM_LICENSE_FILE环境变量不是set.INFO:Security:
68  - 有关获取许可证的更多信息或帮助,请运行Xilinx许可证配置管理器(xlcm或“管理Xilinx许可证”)。信息:安全:68a  - 用户是andrewcapon,主机上是ANDREWCAPONEC68。警告:安全:9b  - 否
'XPS'功能版本2013.10可用于part'xc3s500e'.ERROR:安全:12  - 没有'xc3s500e'功能版本2013.10可用(-5),因此'XPS_TDP'可能不会被使用。没有这样的功能存在。特点:
XPSDoes Webpack不支持Spartan 3E入门套件上的EDK?网页http://www.xilinx
.com / products / boards-and-kits / HW-SPAR3E-SK-US-G.ht表示支持EDK:“ISE®WebPACK™软件,ISE Foundation™软件评估和嵌入式开发套件(EDK)
“谢谢你的帮助。所有最好的安迪
以上来自于谷歌翻译
以下为原文
Hi Guys,
I did open a web case on this but Xilinx rejected it as they said my company name was invalid and now won't let me create a new web case. Quality support!
Maybe someone here can help me:
I have a Spartan 3E starter kit here and have downloaded the Webpack ISE 14.7.
XPS complains on startup about not having a license and hen trying to generate bitstreams fails:
ERROR:EDK - INFO:Security:71 - If a license for part 'xc3s500e' is available, it
  will be possible to use 'XPS_TDP' instead of 'XPS'.
  INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set.
  INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set.
  INFO:Security:68 - For more information or for assistance in obtaining
   a license, please run the Xilinx License Configuration Manager
         (xlcm or "Manage Xilinx Licenses".)
  INFO:Security:68a - user is andrewcapon, on host ANDREWCAPONEC68.
  WARNING:Security:9b - No 'XPS' feature version 2013.10 was available for part
  'xc3s500e'.
  ERROR:Security:12 - No 'xc3s500e' feature version 2013.10 was available (-5),
       so 'XPS_TDP' may not be used.
  No such feature exists.
  Feature:       XPS
Does Webpack not support EDK on the Spartan 3E starter kit?
The webpage http://www.xilinx.com/products/b ... -SPAR3E-SK-US-G.htm seems to show that EDK is supported:
"ISE® WebPACK™ software, ISE Foundation™ software evaluation, and the Embedded Development Kit (EDK)"
Thanks for any help.
All the best
Andy
回帖(10)
王慕涛
2018-12-18 11:04:15
嗨,
使用Webpack许可证,您只能通过定位以下设备XC7Z010,XC7Z020和XC7Z030来访问XPS。
你可以附上你的xinfo和许可证文件进行调查。
您可以从开始生成xinfo  - >所有程序 - > Xilinx ISE设计套件 - >附件 - > Xinfo系统检查器。
以上来自于谷歌翻译
以下为原文
Hi,
With Webpack license, you can access XPS by targeting the following devices XC7Z010, XC7Z020 and XC7Z030 only.
Can you attach your xinfo and license file for investigation. You can generate xinfo from start --> All Programs --> Xilinx ISE Design Suite --> Accessories --> Xinfo System Checker.
举报
陈衡毅
2018-12-18 11:19:39
嗨,转到许可委员会。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi,
Moving to licensing board.Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
刘慧
2018-12-18 11:30:13
嗨Manusha,
感谢超级快速的回复,我想这就是为什么它不适用于这款Spartan 3E主板,但是我使用的是7020主板。
祝一切顺利
安迪
以上来自于谷歌翻译
以下为原文
Hi Manusha,
Thanks for the super quick reply, I guess that is why it doesn't work with this Spartan 3E board but does with some 7020 boards I have.
All the best
Andy
举报
王慕涛
2018-12-18 11:47:11
嗨,安迪,
是的,你是对的。你可以通过仅针对XC7Z010,XC7Z020和XC7Z030设备访问带有webpack许可证的XPS。
您可以在webpack license PACKAGE部分中进行交叉检查。
以上来自于谷歌翻译
以下为原文
Hi Andy,
Yes you are correct.You can access XPS with webpack license by targeting XC7Z010, XC7Z020 and XC7Z030 devices only.
You can cross-check it in your webpack licenses PACKAGE section.
举报
更多回帖
