赛灵思
直播中
李军林
7年用户 186经验值
私信 关注
[问答]
Vivado项目生成比特流时发生错误
嗨,大家好,
我正在开发一个Vivado项目,其中包含JESD IP内核。
我使用的工具是Vivado 2015.4,我们拥有JESD的有效许可证。
该项目的合成和实施是成功的。
但是,生成比特流时发生错误。
如下。
我在网上搜索,发现有些人也遇到了同样的问题。
但我在Xilinx论坛上找到的解决方案不起作用。
我们安装的许可证应该是有效的,我的顾问告诉我他上周刚续订了许可证。
在上周六,我能够生成没有错误的比特流。
今天我对我的项目进行了一些小修改,然后比特流的生成失败了。
在合成和实现过程中没有错误,所以我认为这个问题不是由FPGA设计错误引起的。
谁能给我一些建议?
非常感谢你。
问候,
以上来自于谷歌翻译
以下为原文
Hi everyone,
I'm working on a Vivado project in which a JESD IP core is included. The tool I use is Vivado 2015.4, and we have the valid license of JESD. The synthesis and implementation of this project are successful.
However, an error occurred while generating bitstream.
As follows.
I searched online and found that some people also encountered the same problem. But the solution I found on Xilinx forum doesn't work.
The license we have installed should be valid, and my advisor told me that he just renewed the license last week.
On last Saturday I was able to generate bitstream with no errors. Today I made a small modification of my project, then the generation of bitstream is failed.
There are no errors during the process of synthesis and implementation, so I think this problem is not caused by FPGA design errors.
Can anyone give me some suggestions?
Thank you very much.
Regards,
Tong
回帖(10)
赵雪培
2018-12-18 10:53:55
@onlinext,
从共享快照中我看到您拥有JESD204 IP的Desig_Linking许可证,该许可证仅对模拟有效。
因此,您无法使用此许可证生成比特流。
如果他已经移动或对许可证文件进行了任何更改,您是否可以与顾问重新检查?
一旦正确设置了许可证,您将需要重新生成IP的输出产品,然后运行综合,实施和
比特流。
问候,
赛义德
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@onlinext,
From the shared snapshot I see that you have Desig_Linking License for JESD204 IP which is only valid for simulation. hence you cannot generate bitstream with this License.
Can you recheck with the advisor if he has moved or made any changes in the License file?
Once the License is set up properly, you will need to regenerate the output products of the IP and then run synthesis, implementation & bitstream.
Regards,
Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
---------------------------------------------------------------------------------------------View solution in original post
举报
陈衡毅
2018-12-18 10:59:58
嗨@onlinext
您是否将项目从以前的Vivado版本升级到新版本?
尝试从设计中删除IP并再次添加。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi @onlinext
Did you upgrade the project from previous Vivado version to new one?
Try removing the IP from design and add it again.
Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
赵雪培
2018-12-18 11:12:59
@onlinext,
因此,您无法使用此许可证生成比特流。
比特流。
问候,
赛义德
以上来自于谷歌翻译
以下为原文
@onlinext,
Regards,
Syed
举报
李铃华
2018-12-18 11:30:49
要使用JESD204b ip,您必须拥有有效的许可证。
您可以购买完整许可证或使用硬件评估许可证来获取此类iphttp://www.xilinx.com/products/intellectual-property/ef-di-jesd204/ef-di-jesd204-evaluation.html,查看类似问题https上的相关帖子
://forums.xilinx.com/t5/Installation-and-Licensing/JESD204-preventing-bitstream-generation/td-p/660506https://forums.xilinx.com/t5/General-Technical-Discussion/JESD204B-design
-example / TD-p / 654670
谢谢和RegardsBalkrishan -----------------------------------------------
以上来自于谷歌翻译
以下为原文
To use JESD204b ip you must have valid license .
You can buy full license or use hardware evaluation license for this ip
check this related post on similar issue
https://forums.xilinx.com/t5/Installation-and-Licensing/JESD204-preventing-bitstream-generation/td-p/660506
https://forums.xilinx.com/t5/General-Technical-Discussion/JESD204B-design-example/td-p/654670
Thanks and Regards
Balkrishan
举报
更多回帖
