Microchip
直播中
孙世珍
7年用户 204经验值
私信 关注
[问答]
通过命令行控制ICD4
嗨,伙计们,我们曾经使用命令行中的ICD3和MB.BAT.然后我们购买了6个ICD4来加速生产,因为这个程序员更快,但是它似乎不与Mb.BAT.问题:如何通过外部应用来控制它呢?我们希望自动化它。你推荐的任何文件我们都退房了吗?如何与它进行交互?例如命令行接口、Web服务调用、DLL、API、COM对象、COM端口?如果它只能通过MPLAB来控制的话,它就不适合作为一个生产程序员。特别是我们希望只连接一次程序员,而不是每次编程一个芯片,或者浪费太多的时间。谢谢任何帮助!
以上来自于百度翻译
      以下为原文
    Hi Guys,
We used to use ICD3 via the command line with mdb.bat.
We then bought 6 x ICD4's to speed up production since this programmer is faster.
However it does not seem to work with mdb.bat.
Question: How does one control it via an external application? We wish to automate it. Any documents you recommend we check out? How does one interface with it? e.g. Command line interface, web service calls, DLL, API, com objects, COM port?
As it stand if it can only be controlled via MPLAB it is not suitable as a production programmer.
In particular we wish to connect to the programmer only once, not every time a chip is programmed, or else that wastes too much time too.
Thanks for any help!
回帖(4)
张娜
2018-12-14 16:50:12
你尝试过MPLAB IPE吗?不是最好的工具,但是…
以上来自于百度翻译
      以下为原文
    Did you try MPLAB IPE? Not the best tool but...
举报
蒋荣艳
2018-12-14 17:04:08
嗨,我刚读了《集成编程环境用户指南》,它没有提到API。我们运行了一个应用程序,它自动地对设备进行编程,然后测试它。因此,MPLAB IPE不是一个解决方案。
以上来自于百度翻译
      以下为原文
    Hi,
I just read "Integrated Programming Environment User’s Guide" and it does not mention an API.
We run an application which automatically programs the device and then tests it.
The operator must not start clicking through menus mid way though. So MPLAB IPE is not a solution.
举报
潘璐
2018-12-14 17:22:01
尝试使用IPECMD代替MDB
以上来自于百度翻译
      以下为原文
    Try using IPECMD instead of mdb
举报
张玉
2018-12-14 17:41:30
我很想知道这是怎么回事,因为我想建立一个类似的系统(大概只有4),使用钉床型设置。
以上来自于百度翻译
      以下为原文
    I'd be very keen to hear how this turns out,  as i want to set up a similar system ( probably only 4 ), to use a bed of nails type setup.
举报
更多回帖
