当我们发布MPLAB-X插件的新版本时,我们将最新的库捆绑在一起发布。当插件有一个新版本时,IDE可以为您更新,但是我们做的临时版本通常包括新的部分支持,而不是插件版本,这是McC8的外围库V1.55的情况。这是一个创建的库,如果你愿意的话,它可以让你升级到一个后来的版本。建议你把所有的东西都升级到最新版本,但是如果对你来说重要的是,这个工具生成的代码和以前一样,甚至几年后。然后,你可以选择粘贴工具的版本,就像上次你使用它的时候一样。我可以看到我们真的应该拿出一个文档来描述所有这一切。请让我知道如果有一些问题没有回答,我可以尝试澄清。
以上来自于百度翻译
以下为原文
We bundle the latest libraries with the release when we make a new release of the MPLAB-X plugin. When there is a new version of the plug-in the IDE can update this for you, but we do interim releases usually including new part support more often than plug-in releases, this was the case with V1.55 of the peripheral libraries for MCU8.
The latest version of MCC will load your project with the version of the libraries which it was created with and gives you the option to upgrade to a later version if you want to.
It is recommended that you always upgrade everything to the latest version, but if it is important to you that the tool generates the same code which it did before, even years later, then you have the option of sticking with the version of the tool as it was back then when you last used it.
I can see that we really should bring out a document to describe all of this. Please let me know if this leaves some questions unanswered and I can try to clarify.
以上来自于百度翻译
以下为原文
举报
