是德科技
直播中
张斌
8年用户 224经验值
私信 关注
[问答]
如何让Genesys接受英飞凌0级MOSFET模型
我正在尝试使用英飞凌IPW60R125CP设备的型号。
英飞凌为这些设备发布0级,1级和3级模型。
我意识到我不能使用除0级模型之外的任何东西,因为其他人使用的是一个涉及功能的酷炫模型,遗憾的是,这些功能在Genesys中不受支持。
(希望它们很快就会得到支持!!)无论如何,当我尝试加载Level 0模型时,我会收到与Level相关的错误消息。
我知道Genesys应该支持这个模型,因为它支持3级MOSFET,但我无法弄清楚如何修改已发布的0级Spice模型以使其正常工作。
这是已发布的模型。
为了让它与Genesys一起工作,我需要改变什么?
(我知道我必须反转引脚1和2)。
****** .SUBCKT IPW60R125CP_L0漏极栅极源极Lg栅极g1 8n Ld漏极d1 3n Ls源极s1 8n Rs s1 s2 2m Rg g1 g2 2.1 M1 d2 g2 s2 s2 DMOS L = 1u W = 1u .MODEL DMOS MOS3_NMOS(KP
= 40.755 VTO = 3.85 THETA = 0 VMAX = 1.5e5 ETA = 0 LEVEL = 3)Rd d2 d1a 0.093 TC = 13m。模具MVDR NMOS(KP = 98.67 VTO = -1 LAMBDA = 0.15)Mr d1 d2a d1a d1a MVDR W =
1u L = 1u Rx d2a d1a 1m Cds1 s2 d2 70.8p Dbd s2 d2 Dbt .MODEL Dbt D(BV = 600 M = 0.85 CJO = 32.18n VJ = 0.5V)Dbody s2 21 DBODY .MODEL DBODY D(IS = 15.2p
N = 1.08 RS = 6u EG = 1.12 TT = 750n)Rdiode d1 21 4.66m TC = 6m .MODEL sw MOS1_NMOS(VTO = 0 KP = 10 LEVEL = 1)Maux g2 caa sw Maux2 bd g2 g2 sw Eaux ca d2 g2 1
Eaux2 d g2 d2 g2 -1 Cox b d2 1.99n .MODEL DGD D(M = 1 CJO = 1.99n VJ = 0.5)Rpar b d2 1Meg Dgd a d2 DGD Rpar2 d2 a 10Meg Cgs g2 s2 2.47n .ENDS IPW60R125CP_L0 **
****谢谢,艾德
以上来自于谷歌翻译
     以下为原文
  I am trying to use a model for an Infineon IPW60R125CP device. Infineon publishes Level 0, Level 1, and Level 3 models for these devices. I realize that I cannot use anything other than the level 0 model because others use a coolmos model which involves functions which, unfortunately, are not supported in Genesys. (Hopefully they will soon be supported!!) Anyway, when I try to load the Level 0 model, I get error messages related to Level. I know that Genesys should support this model, because it supports level 3 MOSFETs,  but I can't figure out how to revise the published level 0 Spice model to get it to work properly. Here is the published model. What do I have to change to get it to work with Genesys? (I know I have to reverse pins  1 and 2).
.SUBCKT IPW60R125CP_L0  drain  gate  source
Lg     gate  g1    8n
Ld     drain d1    3n
Ls     source s1   8n
Rs      s1    s2   2m
Rg     g1    g2     2.1
M1      d2    g2    s2    s2    DMOS    L=1u   W=1u
.MODEL DMOS MOS3_NMOS ( KP= 40.755  VTO=3.85  THETA=0  VMAX=1.5e5  ETA=0  LEVEL=3)
Rd     d2    d1a    0.093 TC=13m
.MODEL MVDR NMOS (KP=98.67 VTO=-1   LAMBDA=0.15)
Mr d1 d2a d1a d1a MVDR W=1u L=1u
Rx d2a d1a 1m
Cds1 s2 d2 70.8p
Dbd     s2    d2    Dbt
.MODEL     Dbt    D(BV=600   M=0.85  CJO=32.18n  VJ=0.5V)
Dbody   s2   21    DBODY
.MODEL DBODY  D(IS=15.2p  N=1.08  RS=6u  EG=1.12  TT=750n)
Rdiode  d1  21    4.66m TC=6m
.MODEL   sw    MOS1_NMOS(VTO=0  KP=10   LEVEL=1)
Maux      g2   c    a    a   sw
Maux2     b    d    g2    g2   sw
Eaux      c    a    d2    g2   1
Eaux2     d    g2   d2    g2   -1
Cox       b    d2   1.99n
.MODEL     DGD    D(M=1   CJO=1.99n   VJ=0.5)
Rpar      b    d2   1Meg
Dgd       a    d2   DGD
Rpar2     d2   a    10Meg
Cgs     g2    s2    2.47n
Thanks,
Ed
回帖(1)
李晓婷
2018-12-12 16:33:26
我认为香料中没有一个等级= 0的MOS模型。
然而,网表有一些与sw和MVDR模型相关的错误。
一旦我纠正了这些创世记就能够在模型中读到没问题。
这是修改后的网表。
.SUBCKT IPW60R125CP_L0漏极栅极源极Lg栅极g1 8n Ld漏极d1 3n Ls源极s1 8n Rs s1 s2 2m Rg g1 g2 2.1 M1 d2 g2 s2 s2 DMOS L = 1u W = 1u .MODEL DMOS NMOS(KP = 40.755 VTO = 3.85 THETA
= 0 VMAX = 1.5e5 ETA = 0 LEVEL = 3)Rd d2 d1a 0.093 TC = 13m .MODEL MVDR NMOS(KP = 98.67 VTO = -1 LAMBDA = 0.15 LEVEL = 1)Mr d1 d2a d1a d1a MVDR W = 1u L =
1u Rx d2a d1a 1m Cds1 s2 d2 70.8p Dbd s2 d2 Dbt .MODEL Dbt D(BV = 600 M = 0.85 CJO = 32.18n VJ = 0.5V)Dbody s2 21 DBODY .MODEL DBODY D(IS = 15.2p N = 1.08)
RS = 6u EG = 1.12 TT = 750n)Rdiode d1 21 4.66m TC = 6m .MODEL sw NMOS(VTO = 0 KP = 10 LEVEL = 1)Maux g2 caa sw Maux2 bd g2 g2 Eaux ca d2 g2 1 Eaux2 d g2 d2
以上来自于谷歌翻译
     以下为原文
  I do not think there ever was a level=0 MOS model in spice.
However the netlist had a few errors related to the sw and MVDR model. Once I corrected those genesis was able to read in the model no problem. Here is the modified netlist.
Lg gate g1 8n
Ld drain d1 3n
Ls source s1 8n
Rs s1 s2 2m
Rg g1 g2 2.1
.MODEL DMOS NMOS ( KP= 40.755 VTO=3.85 THETA=0 VMAX=1.5e5 ETA=0 LEVEL=3)
.MODEL MVDR NMOS (KP=98.67 VTO=-1 LAMBDA=0.15 LEVEL=1)
Rx d2a d1a 1m
Cds1 s2 d2 70.8p
Dbd s2 d2 Dbt
Dbody s2 21 DBODY
.MODEL sw NMOS(VTO=0 KP=10 LEVEL=1)
Maux g2 c a a sw
Maux2 b d g2 g2  Eaux c a d2 g2 1
Eaux2 d g2 d2 g2 -1
Cox b d2 1.99n
Rpar b d2 1Meg
Dgd a d2 DGD
Rpar2 d2 a 10Meg
Cgs g2 s2 2.47n
举报
更多回帖
