您的信号是差分信号,还是一侧接地?
如果它是差分的,那么你应该使用差分探头。
根据数据表,您可以选择探头: - 10076B - 250 MHz,100:1,4 kV无源探头 - N2771B - 50 MHz,1000:1 30 kV无源探头 - N2791A - 25 MHz,700V差分探头 - N2891A
- 70 MHz,7 kV差分探头什么是瞬态的BW?
您可以通过使用.5 /上升时间来估计。
一旦你知道了,请选择。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
Is your signal a differential signal, or is one side grounded? If it's differential, then you should use a differential probe.
According to the datasheet, you have a choice of probes:
- 10076B – 250 MHz, 100:1, 4 kV passive probe
- N2771B – 50 MHz, 1000:1 30 kV passive probe
- N2791A – 25 MHz, 700V differential probe
- N2891A – 70 MHz, 7 kV differential probe
What's the BW of the transient? You can estimate that by using .5/rise time. Once you know that, take your pick.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
您的信号是差分信号,还是一侧接地?
您可以通过使用.5 /上升时间来估计。
一旦你知道了,请选择。
以上来自于谷歌翻译
以下为原文
Al
举报
