工程资源中心
直播中
曾培中
8年用户 179经验值
私信 关注
[电源设计]
具有PMBus的12V输入紧凑型双15A POL解决方案
            The PMP6952 reference design is a compact dual 15A POL solution with PMBus in 0.75" by 1.075" size (19mm x27.3mm). It showcases NexFET power block CSD87350 in high-density PoL with PMBus capability.  It is easy to configure as dual 15A or single 30A output with resistor options. It is versatile  (...)
主要特色
  • 8V to 14V in, 3.3V/12A and 1.0V/15A out
  • Peak efficiency 89% at 1Vout, 300kHz
  • Total solution size: 0.75" x 1.075" (19mm x 27.3mm)
  • Option for single 30A
  • PMBus enabled margining and sequencing
更多回帖
