你好
由于您希望拥有kintex7的许可证,因此您可以使用30天的评估许可证。
系统生成器随System Edition或DSP Edition一起提供。
如果您想在Kintex7上工作,您必须在评估期后购买其中一个许可证。
问候,萨蒂什-----------------------------------------------
--- --------------------------------------------请注意
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.--
以上来自于谷歌翻译
以下为原文
Hi
As you are want to have license for kintex7,you can use 30 day evaluation license.
System generator is provided with System Edition or DSP Edition.
You have to buy one of the licenses after the evaluation period if you want to work on Kintex7.
Regards,
Satish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
你好
以上来自于谷歌翻译
以下为原文
Hi
Regards,
Satish
举报
