嗨 - 有两种方法可以进行: - 1)使用* OPC?
当所有待处理操作完成时,它将查询返回标准事件状态寄存器中的ASCII字符1。
2)使用触发类型门。
使用门控触发模式时,该命令选择门的有效状态(门极性)。
当门控信号处于无效状态时,外部触发信号中断回放。
当外部控制信号返回活动状态时,重放开始。
LOW和HIGH选择对应于外部触发信号的低和高状态。
LOW当触发信号变为低电平(激活状态)时,波形播放停止,当触发信号变为高电平时,波形播放重新开始(非激活状态)。
HIGH当触发信号变为高电平(激活状态)时,波形播放停止,当触发信号变为低电平时(非激活状态),波形播放重新开始。
例如,选择HIGH时,激活状态发生在触发信号的高电平期间。
当活动状态发生时,ESG在最后播放的采样点停止波形回放,然后在非活动状态发生时在下一个采样点重新开始播放以下是命令: - [:SOURce]:RADio:CDMA:ARB:
TRIGger:TYPE:GATE:ACTive LOW | HIGH [:SOURce]:RADIO:CDMA:ARB:TRIGger:TYPE:GATE:ACTive?
问候 -
以上来自于谷歌翻译
以下为原文
Hi -
There are two methods to proceed:-
1) Using the *OPC? where it will query returns the ASCII character 1 in the Standard Event Status Register when all pending operations have finished.
2) Using Trigger type Gate.
This command selects the active state (gate polarity) of the gate while using the gating trigger mode. An external trigger signal interrupts the playback while the gating signal is in the inactive state. Playback resumes when the external control signal returns to the active state.
The LOW and HIGH selections correspond to the low and high states of an external trigger signal.
LOW The waveform playback stops when the trigger signal goes low (active state) and restarts when the trigger signal goes high (inactive state).
HIGH The waveform playback stops when the trigger signal goes high (active state) and restarts when the trigger signal goes low (inactive state).
For example, when you select HIGH, the active state occurs during the high of the trigger signal. When the active state occurs, the ESG stops the waveform playback at the last played sample point, then restarts the playback at the next sample point when the inactive state occurs
Here are the commands:-
[:SOURce]:RADio:CDMA:ARB:TRIGger:TYPE:GATE:ACTive LOW|HIGH
[:SOURce]:RADio:CDMA:ARB:TRIGger:TYPE:GATE:ACTive?
Regards -
2)使用触发类型门。
问候 -
以上来自于谷歌翻译
以下为原文
Hi -
Regards -
举报
